IMFURYS
IMFURYS
Well we tore into it a bit tonight. I was able to reshape the LH framerail flange. Got to patch it in a few spots. However considering it was crudely beaten flat against the framerail, I think it looks very good. Patrick started sanding on the nose. Once he strips it, we will squirt a little light grey epoxy primer on it. Tomorrow I will straighten the RH framerail flange, and will start to cut out transition pan. That actually goes in first on assembly, because the floorpan, and trunk floor overlap it.
When Patrick finishes sanding his notch, tell him there is a fastback in VA that he should practice on too, lol. There is also a '72 Fury III that needs a little sanding around the bottom back window.
Seriously though, that's some awesome major metal manipulation going on there.
