74 DART'
Matt are you planning to finish this car completely before you get back to your 67? I know it’s a few years till yours son is ready to drive. Just curious. Great build by the way. You do very quality work!
Next week the kids go on spring break. I rounded up a bucket blaster, a gravity feed spot blaster, and a blasting hood from china freight. I also have some heavy duty rubber gloves, a tyvek bunny suit, tarps and my respirator. Need to get 2-3 bags of crushed glass media from the local Benjamin Moore paint dealer.
Sonny and I been slowly working on stripping the remainder of the parts off the firewall. The ole bag n tag of everything. Will prob pull the hood and front fenders back off to sand blast the firewall on both sides as well as the cowl sides, rockers, door jambs, inside the roof etc. If the blaster and my sand recovery method with plastic tarps works well, I guess we will get it all stripped and into primer.
For now I have been knocking the heavy undercoat and rust scale off everything I can get to. Been using these twisted wire wheel cups. To say these things are brutally badass is an understatement. I wiped out one that I had been using on other stuff, and finished it off scouring surface rust and undercoating. Just bought 2 more from china freight. Word to the wise, use a respirator, and a good set of safety goggles as these things make a bunch of dust you prob dont want to breathe, and little wires shoot off them you probably dont want in your eyes.
I got some action pix. Showed him what to do and stepped back for pix. So far we removed the gas pedal, heater box, steering column, and dash frame. We still have to remove the brake pedal assembly, LH vent box, parking brake handle, and misc parts. Anyhoo without further ado heres pix.
Awesome work, as always Matt.Well I sure wanted to epoxy primer more of this thing at one time, however the areas I had stripped to bare metal were starting to get flash rust in them. I went back over these areas, blew the dust off the metal, and shot what I had cleaned up. Looks good except for the one rusty glue covered roof skin panel I need to strip and primer. Nice, clean, bright, and sealed with light grey epoxy. Better than the factory would have done. Not perfect by any stretch of the imagination, but it doesnt need to be in these areas.
It will be nice to eventually go in the shop and not smell rust dust. Sucks that I have to do all this in that small space. That sanding dust gets everywhere. I try to keep it down and blow it out the door as best as I can.Awesome work, as always Matt.
Got some more done. Not any sandblasting though. I am just not ready to deal with that mess yet. So a special thanks to Davescuda for hooking me up with hood templates for the 69 hood mount turn signals. I finally drilled all that up. I have aftermarket signals they dont use the big stamped cup style nut, so I will have to get some body washers to make up the difference. Had I been thinking I would have drilled the mount holes a little smaller. It's all good though. Adapt and overcome.
The hoods inner structure is disbonded from the skin, and I will have to eventually glue the 2 pieces together. I eventually will need to do some minor dent body work on the hood. But for now it's all stripped of the old finish, and the bare metal wiped down with TSP and water then towel dried. I shouldn't have to worry about flash rust on it if I cant get to it for a week or so. and will get a coat of epoxy primer tomorrow afternoon if I have time. Its amazing that it's actually looking much better than what we started with.
Will do Dan. Might make a stainless steel drill template for you to get holes centered, and just send it. I do sheetmetal for a living so I wasnt skeered.
Well I dont know about " manufacturing the car, but I do want to only have to do this one time to it. Once it's a decent body in white with the underside undercoated and with a decent suspension and rear axle under it, I will likely stop work on it for awhile, and start back up on my 67 and get it to about the same point to where it's a roller with decent suspension under it. I will probably put the 69 back in the garage next to my mustang at that point and it will sit for awhile. I really want to get back on my 67, but need to make this 69 into something decent first.
