moparmat2000
Well your farther along than me Dan. One of yours actually runs.
Next week the kids go on spring break. I volunteered to take vacation and stay home to "watch them". So my evil plan to get some quality time with my son working on the cuda is right on schedule (insert evil laugh here). Ever the constant thinker, I have been preparing for this. I rounded up a bucket blaster, a gravity feed spot blaster, and a blasting hood from china freight. I also have some heavy duty rubber gloves, a tyvek bunny suit, tarps and my respirator. Need to get 2-3 bags of crushed glass media from the local Benjamin Moore paint dealer.
Sonny and I been slowly working on stripping the remainder of the parts off the firewall. The ole bag n tag of everything as well. Will prob pull the hood and front fenders back off to sand blast the firewall on both sides as well as the cowl sides, rockers, door jambs, inside the roof etc. If the blaster and my sand recovery method with plastic tarps works well, I guess we will get it all stripped next week and into a thin wash coat of 2K epoxy primer.
For now I have been knocking the heavy undercoat and rust scale off everything I can get to. Been using these twisted wire wheel cups. To say these things are brutally badass is an understatement. I wiped out one that I had been using on other stuff, and finished it off scouring surface rust and undercoating. Just bought 2 more from china freight. Word to the wise, use a respirator, and a good set of safety goggles as these things make a bunch of dust you prob dont want to breathe, and little wires shoot off them you probably dont want in your eyes.
I got some action pix. Showed him what to do and stepped back for pix. So far we removed the gas pedal, heater box, steering column, and dash frame. We still have to remove the brake pedal assembly, LH vent box, parking brake handle, and misc parts. Anyhoo without further ado heres pix.
Well I gave sonny my 67 valance and hammered it straight. We got more stripped, and looks like my nice day is over.
I removed the crossmember internal tube reinforcements since I am going to be modding this for a 42RH when the floor is out. I figure I am better off scouring the inside with a sandblaster with these out. Was going to just replace them with steel tubing as reinforcements.
I have a weldable steel exit window torque tube from the aircraft I work on that's the perfect diameter and thickness for this. Part was damaged at the linkage end not repairable. About the same wall thickness as these brackets I removed
Dan when she hits 120mph and I pull back on the steering column we will achieve liftoff LoL"You mean to tell me you built a plane out of a Barracuda? I thought you were joking when you said your car(s) we're gonna fly and when they hit 88 MPH, you're gonna see some serious lift!"
Sue me, it's still early, lol.
Those four legged friends are heartbreaking, sorry for your loss !Been trying to get back in the mood to work on things. After I had to put my four legged best friend to sleep back on the 5th of May it's been kinda hard to get motivated on most of anything. I pushed through last weekend to get the pavers done to get it over with.
However I did a little shop clean up/straighten up today though. I also plan on listing some parts I'm not gonna need or use. I did do a simple project today out of some pieces of metal in my scrap pile. Didnt feel like cutting and chopping so I dug into it until I found the right combination of junque to just weld together and paint. The brown bracket was a piece of old bedframe angle, I have no idea what the rest of it was for or from. Anyhoo, I made a better hanger for my jumper cables and extension cords. Originally I had an old bent up headliner bow hooked onto wiring conduit.
