DallasMan2000
My 67 Barracuda windows all need work.
I suspect that the doors are actually from a 1969 Barracuda for the reasons below:
1. The door panels look like a 1969 design - pic below
2. There is a hole in the interior under the window vent - pic below.
3. When I sanded down the drivers door for painting I could see that the door lock was previously near the center of the door. It had been welded over and ground down, then the lock was moved to the back of the window.
You can see from the 2nd pic below that the rubber window trim on the driver’s side is spilt. The passenger side is about the same. The rear windows are stuck in the up position and the front windows need a little help while rolling up and down.
Anyone know what parts I need to buy and where to get them? Also does it matter what year the doors are?
I am happy with the current door locks. This project will be just for getting the windows rolling up and down properly with good rubber trim.
Thanks in advance for your help.
