67 Cuda Notchback Hell Cat Swap
Finished setting up the rear suspension.
Hmm, I got RMS 4 Link and 3" TTI pipes. It's all tight but I think it will all clear. I had thought about running the pipes underneath the rear axle if I needed clearance.
No way with mine. Lowered, tubbed, 4 link, ...
I wanted to run mine all the way to the back, but with IRS, differential cooler, dry sump tank, and battery box all taking up space, I had to go to NASCAR oval tubing just downstream of the mufflers and turn it out just ahead of the rear tires.
