looks good maddart!
the bar going from the main hoop allong the roofline down the a pillar and to the floor was a pain in the tail. we spent about 6-7 hours getting it bent up, and we still need to trim and fit it in the car. nothing like bending tubing multiple angles and triing to get it right the first time. (keep in mind this is my first fab project as well as my first cage)
Well I measured 5 times to be sure and my frame rails were 1 1/2 inches to the passenger side so that translatedto the lower mounts being to one side
I took all my measurements off of pinion centerline.So the 3rd member is off center is what you are saying?
I measured everything off of the axle flanges before I had it shortened and set all my brackets off of the flanges. So I could see the 3rd member off by that much being that the mopar drivetrain sets to the passenger side. Remember all my measurements were taken off of the Flange and I never checked the 3rd member if it was center or not.
Here are the shocks I used.
130lb springs.
http://www.summitracing.com/parts/CMB-15-0058/
