yea im not looking forward to it. im gonna try to avoid short sbutdown tracks. so i dont have to pull the darn thing. or get one of those chute packing tools to simplify it. hahawait till ya gotta pack that 'chute after every stop.
speaking of...my 4yr old pulled the damn pin out the chute and scared the crap outta him. all of 10 sec after i told him dont touch. glad the car was against the wall. spring barely moved and it was enough he wont be touhing it again anytime soon. poor little guy.wait till ya gotta pack that 'chute after every stop.
i just relocated them away from heat and to clean up wiring and give a more nostalgic look. as i think i may end up over powering the coils anways. so ill be able to remount some holley coils in their place rather quickly if i max them or over tax them out.Why did ya go away from the COP?
Ah ok, one of my SBF friends did the same thing. I went with the Holley coils and CNP.
yea there is turn radius lost we knew that from the start, but its not significant at this point and still great compared to some other cars out there onthe road. once we test it and drive if it dont work acceptably. will go to a strut front end. i know it turns better than my 50 pickup does that i just sold.You might consider this test while still in mock up.
Turn the wheel as far as it will go (until the rack stops) and measure how far the spindle turns on the inside spindle. IF turging right, measier the right spindle.....then do the same on a non modified, factory set up. I think you will be surprised how much turning radius is lost with those extended steering arms.
.........just want you to be prepared.
Looking good....always a heart stopper when your factory sheet metal is cut out and you are not there to see it.
MY CAR IS NATURALLY ASPIRATED, AND I CAN`T EVEN HEAR MY PUMP WHEN THE ENGINE IS RUNNING. DOUBT U COULD EUTHER !yea i honestly do not know how its gonna work out putting it somewhere up front. but it has to. there is not an electric pump that will survive the street duties and fuel requirements this thing is gonna demand. id be depressed if i had to run an electric whirling and buzzing pump on my car. drives me crazy hearing one buzz the entire time. l9l
who is the member who has a custom license plate that says "on off" and the kill switch right in the middle??Your killing me.
i could hear my a2000 over my high compression big block chevy making 800hp out 4 inch borlas. it is like nails down a black board to me. trust me..i can hear it. very sensitive hearing.MY CAR IS NATURALLY ASPIRATED, AND I CAN`T EVEN HEAR MY PUMP WHEN THE ENGINE IS RUNNING. DOUBT U COULD EUTHER !
wow autocorrect failed miserably at its job and just threw its hands up in defeat. i win. lmaoYour killing me.
no comment !i could hear my a2000 over my high compression big block chevy making 800hp out 4 inch borlas. it is like nails down a black board to me. trust me..i can hear it. very sensitive hearing.
Sweet. Then we can line you up with the procharged 582 Chevelle at Havana lolwell my block is on the machine work doing it now list. not sure how long for a line hone and bore takes these days. but it is all but hopefully wrapped.up before weekend is up. then off to assy and rumble rumble rumble whoosh phsssss
