Just the burn out?!!! You tease!!!!! How did it go?
last sat made a fee more hits but went horribly the entire night. last pass it finally came around and the driver fed up.
We all will lol. Nice projectActually its an A-body Site. Nobody will know the diff. when its haulin down the strip!
pump e85 for the moment till we lean on it. then e85-r will be used. holley hp ecu and prodash. best so far has been 6.90 @107.8mph. did have a pass i went 7.00 and only ran 68mph. that would have been 80s maybe but didnt make any boost either. non of my passes has seen boost till 4+ sec into the run.What did it run? What boost? Still on pump gas? Are you running Holley EFI?
video above that i removed and uploaded a clearer imagary
yes glide. not trans related. it was ecu related and now configured properly. had the tbrake set like bump box. so when i engaged the brake it acted like a bump box. it dont do that now. we commanded 5psi we got 5psi on the last pass. just didnt stay in the beams to get a slip. it picked up a bunch but we dont know how much. converter is pretty tight but not overly tight as we can get boost instantly off the line. but we need about 15+psi more to get high gear to make some steam to get rpms to climb on a pass. which is expected.I assume that's a glide? Do you think your issue is all trans stall related? Or possibly waste gates? Whats your target boost and what rear gear? Just curious.
yea that sounds like a badass for sure.Much better video. We finally got back to the track as Havana opened up. We were down there with a SBF turbo car. He drove it there and went 6.09 at 120 on pump 93 and 10psi. It’s gonna be a killer little combo. I’m still finishing wiring.
I’ve heard some rumbling on the forums about incorrect pinning on the harnesses. You might check that out on the ecu plug end. The diagram s are pretty clear and it’s easy to check. Has it done this from the beginning?well it runs but it has issues unresolved to date. i think i have a bad engine harness from holley. as crank sync issue wont go away even with new sensors and extra shielding and distancing from other wires. non of my other sensors work either after getting new and redoing the ecu all over. nothing works as intended. so its parked and i could care less right now.
it runs fine for a bit. then turns to ****. i get rpm sync errors. sl showed a shitshow.I’ve heard some rumbling on the forums about incorrect pinning on the harnesses. You might check that out on the ecu plug end. The diagram s are pretty clear and it’s easy to check. Has it done this from the beginning?
Sounds like it’s either cam sync or crank trigger related. Did you post anything on Holley’s forum?it runs fine for a bit. then turns to ****. i get rpm sync errors. sl showed a shitshow.
yea all they wanna do is spell check and complain about how i type my **** out. rediculously and unhelpful as hell. as they chsnge everything i typed out and makes no sense to me after that. so i just quit. i guess i should type it out in russian and see if they wanna spell check me that way. jackholes.Sounds like it’s either cam sync or crank trigger related. Did you post anything on Holley’s forum?
on their actual tech forum you linked yes.
Trust me, there’s nothing secret in there... lol, but I bet they’ll figure out the problem. A lot of smart guys on there and Danny Cabral is good at troubleshooting. If you wanna keep it secret, hire someone to remote in and figure it out.on their actual tech forum you linked yes.
also on facebook didnt get to much help at all. everyone wants my global folder and im not to keen on giving that magical stuff out.
i have to no avail. sent logs, etc.. all danny does is change my posts to where i dont understand it. complains about my writing as if its in text form or some ****. im about to post in russian. so he can translate it and complain about that to and delete my posts all over again.Trust me, there’s nothing secret in there... lol, but I bet they’ll figure out the problem. A lot of smart guys on there and Danny Cabral is good at troubleshooting. If you wanna keep it secret, hire someone to remote in and figure it out.
