So... I started this project with the mind set that I would not be one of those guys where life got in the way and prevented the car from being finished. Well I hate to admit it, but that appears to be the case. I decided it is time to buy a house (well a garage really). Out grew the garage at my apartment and new information came to light regarding the land lord's policies that I decided it was time to move. Which means all funds are being directed into finding and hopefully getting a house in the next couple months... So all of the car parts that were in my apartment are in the process of being stored at my parents place (where the car is anyway). So this past weekend I was able to get about 80% moved there
So in the mean time, my schedule has to change for the GTS and I have to work on the stuff I do have. So this past weekend I was able to go to the parents place and get some work done on the GTS. I got the ignition system hooked up, coolant in, as well as topping off the transmission and putting oil in the engine. Tried to set the dwell but the key wouldnt crank the motor. Jumped the car at the relay and it cranked fine. So after some electrical digging and testing other parts, it was revealed that the relay wasnt grounded properly, so that issue was remedied. Set the dwell and was trying to get it to fire with starter fluid. First was seeing sparks come out of the carb and decided to rotate the rotor 180 degrees and it finally started!! However it died right away. Looking at the fuel filter, there was no gas present. So off comes the fuel pump and it was determined that the inlet and outlet on the pump was swapped, so we swapped connections and still no luck. Pump came back off again and we determined this new pump was bad. Took a pump that was on an engine that has been sitting since the 80's, cleaned it as best we could, installed it, and after some cranking I was seeing fuel come into the filter and then it fired!!! I was able to complete the break in period but was a messy process. The thermostat housing was pissing fluid to no end, so it got all over the floor, initially we thought it was the pump but by the end of the break there was basically a water fall of coolant coming from that housing... So for good measure the fuel pump, water pump, thermostat and thermostat housing will be changed in the near future. That was all I could get done to the GTS.
Got some painting done, got another grille and a set of head light doors painted for the convertible, the bucket seat hinge covers for the charger painted, as well as some headliner trim and trunk striker.
I was able to install the rebuilt tic toc tac in the charger, and saw that I already left the harness in the car for that, finished tightening the front valance and got the parking lights installed and working. Was able to determine the heater will shut off fine, you just need to press the blower switch all the way to the rear. Didnt get the electronic hum figured out but the underdash wiring looks a little prettier now, and the oil was changed. Tried a known good whipper switch, got two speeds (not the needed three) and the whipper motor still wouldnt go back to park, so maybe the motor is bad...
(for my reference)
I am not to sure what direction next to go with the GTS, still need to figure that out, maybe install body panels and start the finish sanding of them, but for the charger the following will need to be done in hopes of getting it on the road in the next couple months: wire tac up to fuse box, wire tac to coil, paint hood latch hardware and install, paint splash shields and install, drill and hook up fuel gauge wire to tank, pretty up wiring some more, install drivers kick panel, install door rubber, install trunk rubber, fix hood turn signals, align hood, align trunk, install windshield trim, get new wiper motor, align the front end, get tires, screw in cluster, install instrument panel trim, install glove box, clean and install hood to cowl rubber, install ash tray, install seat hinge covers. It will be a busy time next time I am back home.
