Longgone
John/68 Barracuda & Dart
I guess I like it OK.
wannabuyit??
Does it come with a straight jacket?
wannabuyit??
I think that this AVS carb still has an issue with the accelerator pump. It doesn't squirt fuel until the gas pedal is almost to the floor, and I bet thats why it is hard to start.Great to hear its running again. Shouldn't need a choke to start it though. Just a few pumps of the pedal and it should fire over. You could have fuel percolation issues after it sits for a while.
These guys are tough as nails! NOBODY gave up. Not once in the whole thread did anyone ever give up trying to get this thing to run. I just wish I could help some of you guys the way I've been helped.Great to hear your over that one.
I stayed out cause any advice I had was already on the table.
160+ posts, almost 3 weeks and the guys kept tryin, So, Great Effort to everybody.:salut:
I'll keep ya in mind Bill. I want to buy it, but I just spent $400.00 trying to get to the bottom of this problem, and I need to let the funds "build up" if ya know what I mean.Glad to hear you got it going again!! - If you decide to go electronic ignition let me know I have the whole kit here at the house - I found a good deal on an "Ignitor" setup on ebay after aquireing the mopar kit - so its extra parts now. I also have that little oil slinger dealie but I guess Im too late to help with that one -LOL
HmmmmmmGlad to hear George! Go with pertronix and it will fit under the cap of the stock points distributor.
Congrats on that 12 second pass! I can only dream of this car running a time like that!Glad to hear you got her running George.I also, got mine together and went to the track today ran a 12.88. Which I was glad just to be driving it after a month of wrenchin and waiting for parts.But oh what a feeling!!!vvvrrroooomm!!Congrats.Oh ya will the kids fit in the car with your big smile!!HAHA.
If the engine is cold, it will not start without the starting fluid. Even after it starts, if I let it stall, it won't restart unless I spray it again. Once it's hot, it will start on its own.Awesome George! It's not a vette but, quite a fun little car to drive!
Hope you get the little bugs worked out real soon. Please don't use too much of the starting fluid. : (
This AVS has a new accelerator pump, and it works like crap too! I wonder if I raise the floats up a bit if it'll work better. The acc pump will squirt good fuel, but only when it's way down in the bore; like 1/2 pedal and beyond.
Well I screwed around with it a bit more tonight.Should be squirting nice and strong just off idle. Do you have slack in the linkage?
Kim-
Gas is brand new, I filled the 5 gal gas can, then put more gas in my Ram from the same pump at the same time so I know the fuel is good. I poured the gas from the 5 gal can into the Dart, then went back and got another 5 gallons from the same pump.
The single wire from the dist is connected to the NEG post on the coil.
I will try the jumper wire from the POS battery post to the POS terminal of the coil tomorrow, kids just went to bed.
I don't think the engine is flooded. Last week I pulled a few plugs after cranking the engine over for (seemingly hours) a while, and they were dry as a bone. Thats why I thought the carb was bad.
I can do a compression check, but like I said the car ran like a top until all of a sudden, while idling in my garage, it quit.
I will check all connections at the starter relay.
All the wiring harnesses from the firewall forward are brand new except for the wiper motor wiring. My wipers don't work, but could this have any effect on the engine running? The wipers haven't worked since I put the car back together.
I wish I had a wrenchin buddy too. I'm about to pay Kim's airfare to come out here and fix this thing for me!
I'll report back tomorrow. Thanks for all the help so far guys.
George
George, Glad you found it... There were a few that said ignition right off, werent there ;)? You can piece together the MP kit. you need a reman distributor (last one i got from Car Quest was $50), a set of Mr gasket light springs, a Std ignition (brand) module also at CQ, and a plug from any mopar in a bone yard. Should cost a total of under $100. If you get the parts and drive it to me, you can drive home with a new HP ignition.
