George R
Mopar Nutcase
I'll check all the new info out, and run the engine off another fuel supply later this am and report back.
Thanks guys.
George
Thanks guys.
George
Haney-Man do I feel for you... I have been there too and it does get almost unbearable.... Hang in there.....
Since this problem started, there has been A LOT of things change so what ever the intial problem was could have got swapped out (like the carb) but now something else is off and thus making this whole problem seem unsolvealbe since you have symptoms of multiple problems......
So... Would you agree that if you are getting gas and spark at the right time, the car should run. It may not run well but should run. With the new carb, you know you are getting gas (you can see it squirt) and while cranking with a plug wire off and grounded, you know you are getting spark. Is there a chance that when you put on the new timing chain that you are 180 degress out? It is really easy to do... When you put in your new distributor when it comes today. MAKE SURE it is close to being in time, at least close enought to start.....
Take out #1 spark plug, put your thumb or finger over the hole and have someone BUMP the starter in until it blows. Once it does this, then rotate your balancer to the timing mark. You are Now DEFINITELY at top dead center. Point your rotor button towards #1 in the cap and drop it in. Now you have to be close. Also make sure that you have the rotation in the cap right to the firing order. The car must run or at least hit if it is getting gas and fire.
Other than that, I would put a fresh set of plugs in... All of that cranking without running may have fouled them. I have done that before in my SB as well.
Good Luck.
Good idea, but I do have spark. I know fuel is getting to the motor because the plugs are wet.I would say, check the points wire coming out of the dist. to the - side of coil. Mine broke inside the dist. once on a car different car a while back.
Bob, I have another starter here, but I have lost the ambition to replace it today. I also have a lot of other responsibilities here at the house that need my attention right now.George, Read my post about my rebuilt starter. Take it out and have it tested! That is exactly what happend to my car. Very weak spark with the starter and a big spark turning the dist. by hand!
This car used to start by just clicking the key, so I know what you mean.George, if you oiled the cylinders you`ll need to spin it over quite a bit to remove that oil or the spark plugs will foul. When all systems are go it won`t take hardly any cranking to start the engine.
I'll have to buy one.The engine turning over freely is also characteristic of no spark. Buy a compression gauge and check it before taking anything else apart.
If there`s anybody out there that can go to George`s house and help out , please do.
George, just seen this thread. I'm not sure about the 340 but on the 318 and 360 and possibly all mopars, when you have the dots lined up on the timing chain gears like the pic you posted on page one or two then you are on tdc of #6 cylinder. Top gear should have the timing mark at the top to be on #1 Not sure if you were on tdc #6 in the pic or not. Just trying to help. If it is 180 out you can just drop the distributor in pointing at #6.
If this is the case, turning the distributor 180° will make it go. I did exactly this on a Pontiac many years ago by throwing the chain in as I'd done with so many Chevy motors.George, just seen this thread. I'm not sure about the 340 but on the 318 and 360 and possibly all mopars, when you have the dots lined up on the timing chain gears like the pic you posted on page one or two then you are on tdc of #6 cylinder. Top gear should have the timing mark at the top to be on #1 Not sure if you were on tdc #6 in the pic or not. Just trying to help. If it is 180 out you can just drop the distributor in pointing at #6.
Longone, he has the timing marks lined for a Chevy at TDC. The marks are not supposed to be pointing at each other if you have the#1 cylinder at TDC on a mopar. they should BOTH be at the 12 oclock position at TDC for #1.
