IT RUNS!
A local Mopar guy named Gary that I met last fall bumped into me at the parts store this am when I was getting my distributor. I told him what happened, and he said to call him after I replace the starter and do a compression test. He didn't think the engine lost compression.
I put the new starter in it, and this one spins the engine over WAY faster than the Carlisle rebuild I had in it.
The comp test showed 170-200PSI on all 8 cylinders, so I got my buddy Gary on the phone, and he came right over.
We rechecked everything, and put back all the new parts that I had taken off while trying to find the problem. No start.
We then checked the new AFB I just got, and it was soaking the intake runners with gas. Might have got screwed up in shipping, I dunno. Anyway, we put the original AVS back on the car, and removed the plugs which were soaked with fuel. I mean dripping wet. Gas vapor was coming out of the cylinders when I cranked it over with the plugs out. We checked for spark, and he said it was weak, so we installed the new distributor that already had a new set of points and condenser in it. Gary thought the condenser in my distributor was borderline, and combined with all the fuel which fouled the plugs, the ignition system couldn't overcome it. I bought a new set of plugs, and he sprayed some ether in the carb. I don't think the engine made one revolution with the starter and it fired to life! I have to retime the engine with a little more advance, but the plug wires and vacuum advance won't allow any more advance. I need to rotate the wires on the cap, or reindex the oil pump drive.
Gary, like most of you, convinced me to switch to the Mopar Electronic Ignition system. I'll have to spring for a kit soon. I'll just hide the box in the car, and run the wires so they aren't noticable.
But it runs! Now I can finish my exhaust system install, get a front end alignment done, and get my plates.
I want to take the time to thank all of you guys who spent so much time trying to help me with this. I am embarrased that I couldn't figure it out, but I wanted to tell all of you that it now runs, and what the trouble was. It wasn't any ONE thing, but a combination of things. I think the plugs went south first, then the condenser died laughing!
Thanks again guys. Like I said, FABO is one hell of a website!!
Big Richie-O, you crack me up man, thanks a LOT for the PM you sent! You made my day man! I wish you lived closer so I could buy you lunch!
George
