swisswill
Who built your hood and what size scoop is that?
Nice!!!!!!!!!! That is going to be righteous!
Great car! You didn't mention the front suspension. I saw the disk brakes but you didn't mention the rest. Anything special? Just curious.
I love your choice of white. Most people would avoid it but it looks GREAT! I really love the color under the hood. That is a lively color.
I know what ya mean about the grease on the engine bay, I had a white 66 Barracuda that had the same troubles, the paint was nowhere near the quality of yours, but it was still hard to cleanI once had a Valiant with a white engine bay and if someone 2 towns over got grease on their hands it seemed to wind up showing on my white engine bay! the Chili-pepper red was actually my second choice. I was leaning toward black but when I started looking around, everyone has a black engine bay. So, red it was, to match the interior.
Larry
Its a metal 2 inch scoop. If I remember correctly I got it thru Sherman. The guy that did the paint did the hood also. Used the scoop as a template and cut out the hood about 1/2 inch smaller then slid the scoop under the hood skin before welding. Left all but the center part of the hood structure in place for strength. Only problem I have found is that, because of the way I have to mount the throttle body to clear the injector rails it puts everything up high. A 14" air cleaner hits the rear of the inside hood frame. So, went with a 10" unit and found that it also JUST hits the edge of the cutout in the hood. I'm going to cut a piece of 16 gage metal today and make an offset aircleaner housing to move it to the front about 1 inch or so to clear.
You might get away with an HEI style 14" air cleaner base. They are moved forward about 1-2 inches to clear the large HEI distributor on sbc's. They sell just the bases as a kit too. Then you get the offset air cleaner stud as well.
