Got my headers... friggin gorgeous.
They look very nice. I have stock 340 manifolds and with a 4 speed it sure seems tight just getting a single collector to the manifold with the steering box, clutch linkage and torsion bar in such close proximity. I am always amazed when I see folks get headers installed, especially on BB cars. I actually installed a mini starter in mine which made me feeler better about gaining more clearance space and being able to pull the starter without yanking other things out. Are you going to run a min starter?
That’s lookin’ like some kinda sweet power plant!! Easiest way on the dash wiring is to yank the dash and work on it on the bench. If your gas gauge is not working there is a mod out there for an electronic voltage reducer that works great. There are some backside dash pics on my album for you to gander at. Love the build you’re doing!
I didn’t consider it, but good to know about it. I did consider swapping to manual, but I just DID NOT want to open yet another damn can of worms on this thingHave you considered a manual steering box, and adapting an EPAS (electric power assisted steering) setup under the dash from a toyota yaris? It requires only an ignition switched hot, and a ground to power it. Theres a few people on fabo that are doing this.
