2026 someday ish lolI’m gonna come up with a countdown timer for our race at renegade to help you get it done in time…. Or to apply some unwanted pressure …. lol
Oh my, Boosted will probably have a W deal running in the 8's by then.2026 someday ish lol
If I’m still alive…. lolOh my, Boosted will probably have a W deal running in the 8's by then.
You better beIf I’m still alive…. lol
I'm trying as hard as I can to get it done for this season and not the end of it.If I’m still alive…. lol
X2026 someday ish lol
I did the same for my upper shock mounts. That bar serve 3 purposes, it also has my down bars through the speaker tray landing on it and my anti-roll bar is tied to it.I put in a upper cross member for my shocks.
Also made a close off point and front mount for the wheel tubs.
Awesome, that is a really nice set up you have there.I did the same for my upper shock mounts. That bar serve 3 purposes, it also has my down bars through the speaker tray landing on it and my anti-roll bar is tied to it.
I have no assembled transmission yet, I still need a few parts for that & I have to build my dana still.Heck the engine is done, the chassis is certified, and I didn’t see any rules stating the body had to be back on. Throw the engine in it and send it.
Just be patient and take your time. It took me over 13 years to build mine as the budget would allow.I have no assembled transmission yet, I still need a few parts for that & I have to build my dana still.
need a converter after I weigh the car & a driveshaft.
only problem is my lack of budget for those parts.
Yep, I have most of everything I need just trying to get it as far as I can before the weather turns.Just be patient and take your time. It took me over 13 years to build mine as the budget would allow.
What is the plate from all-star that is bolted to your dana ?I did the same for my upper shock mounts. That bar serve 3 purposes, it also has my down bars through the speaker tray landing on it and my anti-roll bar is tied to it.
Yeah id love to get a/c for my house and garage.I would rather be hot and sweaty then be cold. However, I have had heat in my garage for over 20 years and about 5 years ago installed A/C. I can't believe I didn't do the A/C 15 years before that also. It is nice working on stuff and not dripping sweat everywhere. 70ish in the garage when it's 95+ outside is nice.
Centerline fixture for mock up when I was narrowing my axle.What is the plate from all-star that is bolted to your dana ?
Oh okay, thanks.Centerline fixture for mock up when I was narrowing my axle.
That's a good point. I think most kits are .134 wall because of this. They do that because at .134 they are still usually at least .120 at the thinnest point.Just a public service announcement about .120 erw steel tubing
If I wouldn't have put in the additional rocker bars my cage would have failed.
He measured my 1st rocker bar and it measured .109 the nhra spec minimum is .120 for mild steel. But the majority of the tubing was legal.
So you guys building cages take notes of that, it would be a crappy day if you had to scrap some of your cage. DOM would be the correct way to go for .120 wall but it should be checked also.
Damn, I guess back in the old days my cage would have certed as a 7.50 car lol.When this certification first started if I went and had my car checked and it failed you were blackballed and every surrounding track was notified. You couldn’t even race the car in a 13 second class where a cage wasn’t needed. Lots of cars for sale before certification attempts were made.
Yeah he was happy when I told him it was a .134 cage but I added those other bars without knowing mill specs lol. Guess I learned something and didn't have to have it the hard way.That's a good point. I think most kits are .134 wall because of this. They do that because at .134 they are still usually at least .120 at the thinnest point.
Assuming he used a sonic tester?Just a public service announcement about .120 erw steel tubing
