mike1965
What spindals did you use
there is a house forsale 2 down from mine..
make it happen
Cool duster. What did the hdk set you back?? Will it use stock spindles?
The passenger side header is almost identical to the drivers other than the collector ending behind the motor plate.. the tubing then goes under the front plate and turns up into one side of the divided housing.. ill take a few detailed pictures when i get back in the US. Im out of the country at the moment.
Its a twin scroll flange.. one bank goes to one side of the twin scroll and the other goes to the other side.. 2.5 tubing will fit pretty much perfect into one side of the t6 twin scroll when mesaged into a rectangle..
