After 17 years of no starting problems I now can't start my 70 340 automatic Duster. I have looked at a lot of these threads to know how to debug this. One thing I haven't seen are what the starter relay voltages are supposed to be. Here's what I measured on mine:
Battery is 12.67V with no load. Battery is new as the 8 year old one was needing to be replaced.
With key in accessory position battery has 12.31V, BA terminal on starter relay has 12.15V, SOL terminal has 0V.
With key in starting/cranking position, battery has 12.00V, BA terminal on starter relay has 11.40V, SOL terminal has 10.92V.
Do these voltages look right? I'm not going to assume anything before I get to the starter itself. For now I get a single click out of the starter relay when trying to start it - no cranking.
Thanks.
Thanks.
