Rapid Robert
"rockover" will tell you WO having to pull the dampener/ tcoverthere might be a way.
HAVE YOU PUT A TIMING LIGHT ON IT YET?
Answer that question please so we won't go slam around in circles. Thanks.
when number 1 piston is at TDC firing...numbe 1 on the cap needs to line up with the rotor...
set your damper to TDC take the cap off and see where the rotor is point....
moving the oil gear also known as the intermediate shaft does nothing for your timing...lining up the rotor and number 1 on the cap is the key.....
probably not..
where ever the rotor lines up at #1 tdc is where you start the firing order. 18436572 from there CW.Doesn't the slot in the shaft need to be positioned correctly to allow the rotor to line up?
Or am I missing something?
where ever the rotor lines up at #1 tdc is where you start the firing order. 18436572 from there CCW.
I usually run mine CW.
massive vac leak. & set the timing marks at 15BTDC. turn dist housing slightly till the magnet is dead even with the tooth. (the rotor will be at either #1 or #6). find the leak first tho, intake gasket shifted/mismatch/open (uncapped) nipple/bad carb base gasket/leaking vac line/hose. EDIT one tooth off on the t chain will shift phasing 15.6 deg on the crank, not sure it'd even run like that unless the chain set/cam was mismarked which it does happen. You might get rockover on #1 or #6 & see if the dampener slit is within a degree or two of TDC. pull the plugs for easy turning. get the slit on TDC & using a 1&1/4" socket/breaker bar move the crank back & forth a bit from TDC & note which (#1 or #6) pushrods both are moving, the cyl that they are moving then move the crank back & forth & hit the spot where both pushrods are moving and are at the SAME height & at that point (rockover) the TDC slit should be within that 1 deg (2 maybe) of TDC & this is with a tight/no slop chain. if so your phasing is OK & the prob is elsewhere & you dont have to open up the t cover & mess with the chain. keep us updated on how it goes. MORE EDIT for dist phasing, with the slit at 15 BTDC and the magnet dead even with the tooth, the rotor should be pointing (with springs retracted which they should be at rest) somewhat close to the cap terminal and the can will shift it CCW (on a SB) from that at rest position when it starts and you are above ported. SHORT VERSION: Confirm cam and dist phasing (dist phasing first cuz its easier) & if one of them ain't it then start searching for a vac leak
Decide which valve cover you want to pull (some have more addons to deal with). If Dr VC then turn crank till the dampener slit is at TDC with rotor is at #6 plug wire. If Pass VC then turn crank till dampener slit is at TDC with rotor at #1 plug wire. pull the plugs to make for easier turning with the 1&1/4 socket/breaker bar. with the breaker bar move the dampener till the rocker arms on either the #1 or the #6 cyl you are working with are at the same height (amt of open or closed). go back & forth a bit till you get it (the height) dead on. at that point the dampener slit must be within a degree or two of TDC on the timing marks. this will confirm (hopefully) that you are good dot to dot and there ain't no gross errors in the crank keyway (wouldn't be that IF it ran OK prior to rebuild ex for being worn out) or the new timing gear keyway slot or where the dot was (mis)stamped or if a person used the wrong dot or a cam can be fubared (rare tho). If its off then open her up. If we are good on this then back up the dampener slightly to 15 BTDC & install dist with can on pass side with room to be turned and the magnet lined up dead even with the tooth and if you are doing rockover on the #1 rocker arms then install dist bottom tang so the rotor is facing rearward and if rockover on #6 then have the rotor pointing forward. eyeball if the rotor is under or fairly close to being centered under the cap terminal. if forward plug in #1 plug wire there and if rearward plug in #6 plug wire there. This covers cam phasing, dist timing. Holler back which how it goes, I'm ready for some breakfast & coffee! EDIT if you are a (tchain) tooth off then you'd need to open it up & move the cam. I ain't thinking that, but a vac leak keeps hitting me the more I thinkJust re read this! I get it now. Your saying if my cam is out of phase by one tooth it would be corrected by setting the cam 15 degreed BTDC and then inserting the oil gear rotor &cap pointing at #1 cylinder and starting from there. I'm gonna give this a shot. thanks
FYI....This point of equal lift may as much as 6 or 8 degrees off TDC if the if the cam has different durations for intake and exhaust and had ground in advance, plus errors in the damper markings. If it is up near 15 degrees off or more, then look for something to be a tooth off.with the breaker bar move the dampener till the rocker arms on either the #1 or the #6 cyl you are working with are at the same height (amt of open or closed). go back & forth a bit till you get it (the height) dead on. at that point the dampener slit must be within a degree or two of TDC on the timing marks. this will confirm (hopefully) that you are good dot to dot and there ain't no gross errors in the crank keyway (wouldn't be that IF it ran OK prior to rebuild ex for being worn out) or the new timing gear keyway slot or where the dot was (mis)stamped or if a person used the wrong dot or a cam can be fubared (rare tho).
When its opened up make sure the cam is not a boat cam, they made a reverse rotation 318 for boats. Could have got in there. Just a thought. If it were me and I opened it up and found valve timing is spot on, I would swap the camshaft. :burnout:MTthat's what i thought. thanks for your help. I guess I'm gonna open her up.
it sounds great with the throttle pegged. as soon as i start to let off it shimy's and dies.
