Rapid Robert
a strip of paper 1.329" will give you 21 deg and a strip 1.835" will give you 29 deg. #1 first confirm the new slit is exact TDC
Hey Del. I asked the OP for the cam ID and looked up the cam and it is a symmetrical intake-to-exhaust design. If you check out the open/close points, it works out to show a 4 degree advance. The whole point of this check is a quick check of cam timing to see if it is close to where it should be (4 degrees advance), or is 15 or 30 degrees off, indicating that a sprocket is off. It is not meant in this case to be a method to actually set cam timing exactly.YOU CAN NOT GO BY THAT!!!!!!!!!!!!!!!!!!!!!!!
That used to be known as "split overlap" and does not apply and has not applied on engines for DECADES due to cam designs
Oh, we're more wound up (on this one) than you are. Maybe!I wont be able to work on the car again until fri afternoon. It's killin me.
Progress! Now we can either do rockover or degree the cam then yes all that is left is that pesky vac leak possibility unless there is an off the wall possibility that we have overlooked (as a potential) . With you haveing a symetrical cam I would do rockover.I'm starting to lean towards vaccum leak. any thoughts?
Odd, what carb? New, used?
I'm starting to lean towards vaccum leak or throwing a match in it. any thoughts?
You can measure from spring height (top of retainer) to any fixed point down around the spring seat. The point is to find the height on both intake and also exhaust springs when they are un-compressed (no cam lift), and then find the point where they are both compressed the exact same amount at the same point in crankshaft rotation. From looking at the cam specs, the valve lift is probably going to be somewhere in the .040"-.060" lift range on each valve when they are equal.i bought i digital caliper today gonna measure for rockover tommorow. So when I measure it I'm looking at the spring seat to spring height correct. ?
