727-4 ProStreet Reverse Manual Shift
$1,487.36
[URL="https://www.coperacingtrans.com/images/pixel_trans.gif"][URL="https://www.coperacingtrans.com/images/pixel_trans.gif"][URL="https://www.coperacingtrans.com/images/pixel_trans.gif"][URL="https://www.coperacingtrans.com/images/pixel_trans.gif"][URL="https://www.coperacingtrans.com/images/pixel_trans.gif"][/URL][/URL][/URL]
[URL="https://www.coperacingtrans.com/images/trans1.jpg"][URL="https://www.coperacingtrans.com/images/trans1.jpg"][URL="https://www.coperacingtrans.com/images/trans1.jpg"][/URL][/URL][/URL][/URL][/URL]
Built by John Cope, this transmission is for Mopars with 500 and up horse power driven on the street and or strip. Comes with a free freshen-up. Includes:Glass beaded case & tail housing in side & out, CRTs -22X Reverse manual valve body with low band apply, Bolt in sprag, Alto Red Eagle racing clutches, Kolene steels, Thicker band strut, Red lined bands, Teflon rings, Rear billet servo, neutral switch, 2 cooler line case fitting, 4.2 2nd gear lever, Mopar reusable pan gasket, CRTs deep aluminum oli pan & billet filter extension, Modified pump support.
Available Options: Drum Upgrade:Billet Steel Drum (+$526.07)
Rear Support Upgrade: Rear Roller Support (+$100.43)
Sprag Upgrade: Ultimate Sprag (+$90.87)
Loaded with everything $
2287. This is the one I'm getting.
