Mad Dart
Nothing to see Here!
And the games begin! I think I have been here before?? Lol
I should have it all tore down by tomorrow night~
The body line is set at ride height + 10"... I set the rear down 2" more than it was and the front down 1 " from where it was. It should be in the ball park once it is back on the ground.
I will be checking it with a laser and getting it dead nuts before setting the Ladder bar in the car. The Laser will also be shot front to back for a true centerline. Lines will be snapped on the ground and sprayed over with clear lacquer so they don't disappear. Everything will be built using the lines to square up the car.
FYI what is in the car now is WAY off so I can not use the leafs nor the attachment points from what is there from the previous owner...... It is all catiwampus! LOL
