SpareParts
Dumb kid with a street car? Sanbaggin Cheese Farmer more lik it!!! LMAO
Ray
I don't even have a cage... or slicks... or fiberglass!!! Lol
Ray
What wheel tire combo are on the back of the car currently? Did you have to stretch the wheelwell to make it work, or did you just move the axle back?
Mad, I don't think anyone is knocking you dude...I was just busting your balls! LOL
If the street is your thing, aint nothing wrong with that. For me with a car like that it wouldn't be about impressing anyone by taking it to the track, but just get an idea of what it can do...I mean, aren't ya slightly curious?? Just a bit...?? LOL
What are you hoping it runs?
Ray
13.50 on juice?![]()
On a true 200 you should pick up more than .4
If you go 6.85-100, I bet on a 200 it should run 6.20ish- 107+
Just busting your balls because it seems the in thing to do.![]()
That thing sure sounds good! ! ! What rear wheels are those? Are they bead locks or just rim screws? I can't tell on my phone.
That sounds good Louis, your home made chamber with the dynomax sounds mean.
In case you didn't throw one on already
http://www.jegs.com/p/Wilwood/Wilwood-Rotary-Style-Proportioning-Valve/744516/10002/-1
Dr diff........A '73 and newer disc brake equipped Mopar came with a 1 piece combination valve. It included metering (hold off), as well as proportioning.
First, install a drum brake distribution block (NO proportioning or metering) in place of your stock proportioning valve.
If your rear brakes lock up before the front brakes, add an adjustable prop valve in the rear line.
I smell a custom front k-member and rack and pinion steering in your future.
