You can do that cable without a shop. BUT a Helper for a few minutes would make it easier. Here's the Deal, they Are adjustable, almost infinitely. Unless You know a Guy, or Shop Owner, You ARE GONNA waste money... are they going to charge you hourly when you spin it around the block and don't like the shift points and you want to keep tweaking it or they just going to put it on and then give it back to you, and then you can adjust to get home as what most everybody does? Not being Negative, just trying to help! Today ain't hard it might seem a little silly at first but if you can throw a cable on a bicycle you can throw one of them on manMore coats primer and I managed to get Pro Form installed. Couple hoses to do and bleed the brakes. Need to do the Lokar kickdown cable still. Plan to get alignment soon and maybe trans shop for that cable want it done right. Need to buy the paint make a plan for the final push and enjoy on road a bit.
My fear is getting it on right and of course there is no room. Lol things I would do differently put the column shifter linkage on first and kickdown cable before I put the new headers on. But I didn't plan on the new carb or the linkage. Same for the brake distribution block. Headers sure don't give you alot of room.You can do that cable without a shop. BUT a Helper for a few minutes would make it easier. Here's the Deal, they Are adjustable, almost infinitely. Unless You know a Guy, or Shop Owner, You ARE GONNA waste money... are they going to charge you hourly when you spin it around the block and don't like the shift points and you want to keep tweaking it or they just going to put it on and then give it back to you, and then you can adjust to get home as what most everybody does? Not being Negative, just trying to help! Today ain't hard it might seem a little silly at first but if you can throw a cable on a bicycle you can throw one of them on man
Yeah I don't think it did but I have been using that where I can got a nice big can of it.Don't forget a Lil anti seize, Cain't Remember if it came with it or not...
Little birdie told me the KB107s are bad news guess I will go for a better flat top or valve relief piston.Found a reputable place in Tulsa to rebuild my engine.
The Plan
KB107 pistons std bore KB107KTM-STD
Comp cam K20 224-4 grind CRS XE274H-10
J Heads add 2.02 intake valves cam is a kit has the new lifters and springs and such.
Balance
Need to get an new oil pan NY East coast did a number on it little rust not chancing it and new deep trans pan.
If all goes as planned I will be way better and below my budget I was planning for. End of the day I want to drive the car and I want to be able to cruise to Tulsa and back and have fun. This is my first car and it was a starter. I have a car someday that will replace the Dart. That's an E body Plymouth of course.
While apart I can paint engine bay jams doors and car and not worry. Be ready to roll when it comes back.
KB KB107KTM-STD Keith Black KB Performance Hyper Piston and Ring Kits | Summit Racing
COMP Cams K20-224-4 COMP Cams Xtreme Energy Cam and Lifter Kits | Summit Racing
Looks,great with the scoop.Got back out bolted down the scoop I need to cut out the two middle pieces in support of for scoop on each side then done. Hopefully it cools off soon so I can start painting again. Kind of annoyed with hot weather here Oklahoma, it does get very cold here and I'm ready for fall again!
I glassed the bejesus out of it lol....it better not cry!Looks great! Hopefully that scoop does not crack on you in the middle. Had one crack on me, but it was in a different location.
