Yeah issue is I won't be using a lot of so it why spend this kind of money when I'm going to cut it up for after market gauges and such. Just irked pretty sore about this purchase. I did look at year one but I figured this would be better than it is and it's not. If I wanted a GM kit would have ordered one sorry I don't get the love affair with GM at all. Can't stand it and this just pissed me off I got a GM kit.I bought a reproduction Harness from Year One a few years back, and it was beautiful. ll the connectors were just like original.
Oh wow that's a game changer the power deal wow I like that! I'm going to lay this all out in car and get to where it needs to be I think I can mount fuse box to the right of the old hole. Put in a plate and run a 1 inch rubber grommet and pass wires there and back via old locations back down sides that should be easy part. I can use the front headlight connector from the new relay harness I bought and will work great. I will get a hold of Francis as I would like to get proper connectors for wipers and other side of ignition harness and turn signal.One of my favorite electric tools is this I borrowed one during this project but now just recently bought one. And if you notice there's a click on coupon at the very bottom I did that and got it for $42 to my door the very next day.. this what you applied 12 volts with just a mirror 10 amps that doesn't do any damage to anything will you check wires and continuity and all your connections and pe-run stuff as you hook it up..
This in a simple screwdriver with a wire that lights up style continuity tester is all you need...
Like both of the windshield wiper motors that I had were no good... Instead of having everything all hooked up and then have to pull it all back out I figured that out ahead of time.. and remember 10 amps isn't going to run the headlights the tail lights the blinkers the windshield wipers and all that stuff it's just for testing each circuit one of the time...
So what's great when we share these pictures of work you get great ideas from others. I'm going to move relay under the battery tray! Nice hiding spot hopefully I can get a few more tips on hiding some of this. What sucks is it's after the fact that I painted the engine bay. Had I wired this first and already had windshield out I could have done this will all this with all the holes welded closed I won't be using! I know I can get some little flat caps and paint those. Bummer! But if I do another my plan will be very different from my toy. This a go fast fun car driver not a trophy winner. Could be with a little work here and there. I leave that for now for those with more time and patience than me. Glad I didn't pack up stuff and cover car.We got lights/parking super excited moving along and dimmer works as well. Gotta finish up some more no test on the signals yet gotta get to the back of car sort out that fun. Plan to keep my new wires I ran to tank and ground. I will see what they supplied for gauges and feeds as they are nicer than what I had made previously. I will take a look may be worth cleaning it up.
Ok now my gauges and cluster and I don't have things happening lights all working. Blinkers brakes dimmer and brights. Start tiding things up now. Oh the right rear taillight bulb was not in right I guess. Oh what fun! Finish up sensors and signals for cluster. Then I can add start on the AC.
That's cool...
I'm glad I didn't do red my buddy since 7th grade comes over. He looks at it grins looks at me. I said dont do it! He says wait for Michael Knight is Knight Rider....I told you all this would happen. He was bummed I can't change to red lol.That's cool...
