.......Got it all back together realized the tie rods looked off they were! Then I check driver lower ball joint absolutely garbage machined. Didn't finish the hole where taper is set. So see that I blew it all apart sent everything back but bushings and upper ball joints. Stay away from AR resto parts. Very unhappy took a week off pretty much so now I get to put it together again touch up the paint I'm pissed. Then of course wth is up with height for a arm lower for torsion bar set and taking out the bump stop is wrong I never did this on my 73 Duster that way. The books on this are terrible just pop the bar in I'm the height bolt having it smashed into adjuster didn't come out that way. I read if right jack the lower a arm all assembled and then insert the bar with adjuster arm level should be about ride height correct? I added some pictures just frustrated and it's probably right just irked right now vent over lol. Bottom picture should be able to see the lever adjustment bottom with bolt backed out will do that on ground. I hope this is right or I can do it again it's ok tell me it's off won't hurt my feelings.
Hahaha exactly I had short man syndrome meltdown hahaha. It's going back now I was just not happy the mess I found with the ball joint and other stupid stuff ensued. Cheap Chinese inner tie rods as well that sent me over the edge........
I call it the struggle... After doing it long enough you learn to embrace the struggle and expect it...Hahaha exactly I had short man syndrome meltdown hahaha. It's going back now I was just not happy the mess I found with the ball joint and other stupid stuff ensued. Cheap Chinese inner tie rods as well that sent me over the edge.
