moparmat2000
457 fits mopar driveshaft and ford yoke.
I'm having a hard time finding the flange that uses the 1330 joint the only one I can find is a flange with 1310.
Yea I know I cant seem to find one! Does this look right?Stock exploder 8.8 yoke uses 457 joint
Looks right. I'll go measure the bolt circle.Yea I know I cant seem to find one! Does this look right?
Maybe I can find a stock one someone has left over or didnt use.Nope exploder swaybar wont work. Have no idea on the yoke you have pix of. I got stock yoke with exploder rear when i bought it.
I used a conversion joint maybe the part numbers in the photo can help.Looks right. I'll go measure the bolt circle.
Thank you very much this is what I have been looking for. Was your driveshaft a standard mopar shaft? I'm not sure I'd the joint size changed from 67-75.but that is a start thank youI used a conversion joint maybe the part numbers in the photo can help. View attachment 1715350507
Yes, original to my slant six 67 barracuda it was in good shape. My car is under 300hp. I had a choice at the drive line shop and I listen to his recommendations. He said he could build me one that would handle 600hp for just shy of 300 bucks or I could cut mine down and be in for under 150 bucks. I’m building on a dime so obvious choice was to cut my original down.Thank you very much this is what I have been looking for. Was your driveshaft a standard mopar shaft? I'm not sure I'd the joint size changed from 67-75.but that is a start thank you
Good to know mine was a slant as well!Yes, original to my slant six 67 barracuda it was in good shape. My car is under 300hp. I had a choice at the drive line shop and I listen to his recommendations. He said he could build me one that would handle 600hp for just shy of 300 bucks or I could cut mine down and be in for under 150 bucks. I’m building on a dime so obvious choice was to cut my original down.
Looks right. 4.25 bolt circle (confirmed), 1330 u joint.Yea I know I cant seem to find one! Does this look right?
Heck if know!! Haha I'm just going off what everyone else has used. If I can find a companion joint for the Chrysler driveshaft to 1310 that would be ok with me I'm just concerned about finding the right ujointLooks right. 4.25 bolt circle (confirmed), 1330 u joint.
Or do you need 1310? Lol
Yes that is exactly what I have been looking for the matching part numbers for both parts thank you very much!! I found the yoke for 30 and the joint for 15 so for 45 bucks total I'm in business. I just gotta find the moroso spring perches and I'm good to start cut chop and rebuilding!Remember I had to shorten my drive shaft. Those part numbers in my photo has the the u joint and spicer flange get them both.
Thank you that sounds about right. That is exactly what I was gonna do. Just go off my old one.I removed my original axle and measure it with an angle finder. With the axle upside down I put a level on the spring perch and leveled it. I then put the angle finder on the pinion flange, it was -7* which would become positive if I flipped the axle back up right. My transmission measured at -2* so in theory +2* on the axle would have aligned drive line angle. I think I settled right at +4* for the perches and welded them. So far in the car I have no issues. It’s hard to explain it. Use your original measurement on the the original axle if you still have it. I’m sure others will chime in.
