Dulynrod 66cuda
Why does the 904 leak just sitting. I recall someone mentioning a common problem with these but I can't find it now. also, do I need special tools if I install all new seals?
Not trying to be a smart a$$ but install with silicon lubricant or wipe silicon type sealer around the tube.Silicone the dipstick tube. Third time I've mentioned this in 7 days. I'm no transmission expert but my transmission expert is an expert. He says to silicone the O ring on the dipstick tube.
That can be a good repair if you do it right and the only way is if the tube and transmission are both bone dry. Otherwise, silicone ain't stickin to chit.Silicone the dipstick tube. Third time I've mentioned this in 7 days. I'm no transmission expert but my transmission expert is an expert. He says to silicone the O ring on the dipstick tube.
Just as JYH states above ^^^.65 and older park cable, housing, are common leak areas.Thanks for the tips. I’m guessing one or both of these issues is the cause of the problem in the attached photo.
Sealant. I should have been more specific.Not trying to be a smart a$$ but install with silicon lubricant or wipe silicon type sealer around the tube.
SN: if people just used the search feature as this has all been covered about as many times as “what tire / rim combo” fits a duster
Thanks ! I appreciate that clarification.Sealant. I should have been more specific.
Does it work? I haven't put the idea to use yet.Thanks ! I appreciate that clarification.
I have been doing that for a long time already but did not know if you knew something I did not with silicon lube.
Little silicon sealer on the o ring works great. Helps slide it in and seals it up nice. Not obnoxious or anything.Does it work? I haven't put the idea to use yet.
