WOW ! I can't put 600 tq on any drivetrain part exc 8 3/4 axle, unless I get on it from a rollI'm agreeing with you
Never said you did, Brooks James said 530 hp at tire, I'm saying crank.
Probably torque will be in the mid 600.
Even my driveshaft is rated 500 hpWOW ! I can't put 600 tq on any drivetrain part exc 8 3/4 axle, unless I get on it from a roll
Looks like I'll have to detune my plan to 500 hpEven my driveshaft is rated 500 hp
Yes, I forgot a nitrous controller and an MSD 8680, dash controlled timing plus minus 7.5 degreesYou can do it in stages.
I'd be very happy with 425-450 rwhpIt’s not uncommon to see a 15-20% loss at the tire.
So, to end up with 530RWHP, you’d start with 620-660hp at the crank.
I’m not seeing it out of that combo.
IMO I would say no to the cast crank and hyper. pistons , I went as fast as 10.70s with a stock bottom end 360 crate motor but it didn't last long before we upgraded everything to better parts like a forged crank etc. I am not a big fan of nitrous , I saw the damage just spinning a bearing on a non nitrous stock crate motor did I couldn't imagine the destruction done should the cast crank let go using it.Yes, I forgot a nitrous controller and an MSD 8680, dash controlled timing plus minus 7.5 degrees
Thanks !
NA should be able to do thatAs long as I can fry the tires and leave 2 long identical black stripes
On the asphalt !!
Thanks
I'm prepared for an explosion, I have a 360 Magnum, an a LA 360 E58 (cop motor), one here mag, E58 in storageIMO I would say no to the cast crank and hyper. pistons , I went as fast as 10.70s with a stock bottom end 360 crate motor but it didn't last long before we upgraded everything to better parts like a forged crank etc. I am not a big fan of nitrous , I saw the damage just spinning a bearing on a non nitrous stock crate motor did I couldn't imagine the destruction done should the cast crank let go using it.
shoot, 325hp and BFG's with 50psi will do that all day long and you probably won't even knock that much mileage off them hard *** thangs.I'd be very happy with 425-450 rwhp
On the asphalt !!
Thanks
How much is the car going to weigh out of curiosity?Wallace Calculator shows 11.70 for 450 HP on my Dart, yes assuming after tuning and or modifications
Maybe just get the car running and driving, enjoy it and build a nice "well thought out" engine for the future.Looks like I'll have to detune my plan to 500 hp
my 100k mile 68 std bore 340 shortblock is loose but tight 169 cranking psiI'd be very happy with 425-450 rwhp
On the asphalt !!
Thanks
With my fat *** in it at 250How much is the car going to weigh out of curiosity?
Race 3500# stock 3050#
Slant 6 frame k
Stock bodied small blk
8 3/4
904 Trans
It seems a bit of a porker to me
plot twist: it's a mustang!What kind of car is this
*pulls off brooks mask*
it was DTM all along!
[everybody groans, somebody faints, somebody else vomits]
DTM: and i woulda gotten away with it too if you nosey nellies didn't ask so many questions!
