Same here.Following.
Mine will be for an early A body.
sureAnybody want to see how I figured out the kickdown linkage/throttle cable setup, and the remote mount transmission cooler setup?
Anybody notice how I have it attached at the lower end to the trans crossmember bracket using a stock transmission plastic lower rod bushing, on a custom bracket welded in place to the crossmember. Honestly, this is probably the only way to do this.If you are using a factory console automatic shift the torque rod that goes through the floor is located in a way that interferes with the A500 trans case. If you look at post #50, second photo, you will see the elegant, engineered solution the MoparMatt2000 developed to fix it. I used this solution and after over 13,000 miles I can attest to how slick and smooth the solution works. If you ask really nicely, and he still has the jig he made to modify that rod, you might be able to pay Matt to re-engineer your rod... maybeView attachment 1716315037View attachment 1716315038
I'm sure the mods I did will work with an early A body. I did have to clearance the trans tunnel sheetmetal in a few spots with a hammer and a lead shot bag. Nothing visible when the carpet is put down.Same here.
