[WANTED] A833 shifter needed for A body
Dne007
Cypress, Tx
Hi, I now have a shifter hump, and an A833 for my '63 Dart. The shifter which came with the trans was just pulled out of a box by the seller of the A833~ I actually don't know if the shifter is any good or not. The shifter does not fit the shifter plate on the transmission. Plus the shifter rods are too long. So, that being said, I'd like a shifter or advice is always nice too. I feel I need the shifter to install the hump correctly.
thanks
dne'
thanks
dne'
Hi looks like a pickup/van shifter you can tell by the grease fitting, it is a hurst and with the correct mounting plate & linkage rods it should work
hope this helps.
Joe
THank you Joe, that gives me a little hope, just need to find the plate which bolts onto the trans;)
dne'
The 'early' hurst shifter body and handle are different. I have what you need but will have to take photos of what I am talking about.
red
I DID NOT KNOW THERE IS A CONSOLE! lol I'm interested in this, and in the fact I could have a console, granted that they can be found?
Hi;) This is what I have.
"Are you going to run a Standard or Overdrive transmission? What linkage rods do you have?"
What's the difference between a standard vs overdrive? I have a 4 speed right? The shifter which was basically given to me doesn't fit the shifter mount. I have no linkage.
The shifter you posted looks really nice, but~ I'll give you a call around 10ish, I'm headed out to cut some of the tunnel for my "new" shifter hump;)
Is this yours? I'm a little confused
this is before I had removed all the black paint, does have the shifter levers
[/URL]
this is before I had removed all the black paint, does have the shifter lever.
I'll guess that is a 66 A-Body Standard 4 speed trans. What is the casting number on the tail housing? The shifter mounting plate looks like an Inland. That is why the 68 up shifter is not positioned correctly on an early A-Body. Probably tight through the small 64-65 hole in the hump. Yes, that is my Inland shifter assy on one of my transmissions.
