Cam. Now you need to go through 150 threads to figure out which one is the best.
Chop, Chop!!!!!! Here's a link. Cams for 318's
We should be asking YOU this question. Lolit isn't about money. It's hypothetical question. "Which lowers the ET more: A good head on the stated above car or a good cam?
Chop, Chop!!!!!! Cams for 318's
One of the things I question myself is .... when I did the cam swap only, it was back in the day. Cams are "smarter" so to speak? Maybe now, the cam would produce more of a result ?? But heads have come along way also.We should be asking YOU this question. Lol
True! But a 360 magnum has a much better head to start with, so the cam will produce more results vs a stock 318.Best bang for buck, cam. I was very impressed with the video that a cam was slipped in a 360 magnum and gained 60 hp, all else the same
Closed chamber heads will only raise compression a half point. If you are building a performance engine you will need pistons any way. Ones that make compression and a big cam to make it all work. Oh and headers, and a converter and rear gears. 318 is just adding to a stock engine. Even closed chamber big port heads won't help make a stock cam work. They are pretty anemic.Maybe heads if you up the compression and run high octane fuel. 6 of one half a half dozen of the other.
Let the cam grinder pick one out for you. (and not Comp)One of the things I question myself is .... when I did the cam swap only, it was back in the day. Cams are "smarter" so to speak? Maybe now, the cam would produce more of a result ?? But heads have come along way also.
yes, that would be huge!!! But, in my personal experience, I didn't use the "best heads" either. In fact, they were cast heads. I don't know what my experience would have been with, per say, a new set of eddy RPM's....Let the cam grinder pick one out for you. (and not Comp)
answer, the most average horsepower.*WHAT MOVES THE CAR QUICKER IN THE QUARTER MILE?
Like I mentioned before. If you are only doing heads or only doing cam, I think the cam will do you the most good. If you are thinking about adding the other later you might as well keep what you have and build a engine with a purpose. Like me and my 70 318, It has dual exhaust and a Pertronix. I have a LD4B and a AVS2 to put on but I haven't yet. I also have some 68 340 manifolds and will replace the exhaust. Half of it is till the original single split and made into duals. Get the intake off I am staring at the cam and the 50,000 mile old original timing chain might need replaced. Hell, I might as well pull it and build it with the Speedmaster heads I have stored in the basement. Or better yet, get a 360 Magnum. Where does it end? There is no good answer!yes, that would be huge!!! But, in my personal experience, I didn't use the "best heads" either. In fact, they were cast heads. I don't know what my experience would have been with, per say, a new set of eddy RPM's....
well.... 318 cam would be .399 lift ....answer, the most average horsepower.
>The stock cam is 240/248/112/.420lift and has 20* of overlap. But without a tuned exhaust/headers the overlap period will do nothing for the engine.
but
>In at 110, that short period cam has a loooong compression stroke of 130 freaking degrees. and; That short period cam has a Powerstroke of 122*, and
And '72 is the last year of hi-compression.
>Back in the day, stock 2bbl, 72 318 A-bodies trapped just short of 80mph, it didn't much matter what gear was in there, 80 was it. ..... because it was at the top of Second gear; a shift slowed you down, and 3.23s were long-ago outta steam. The 4bbl will get you there just a lil quicker, but maybe not, cuz you'll just run outta rpm a lil sooner. If you shift, you could be slower. If you don't shift, your average power will fall off.
>If the 3.23s have to stay, and if your 318 is one of those higher compression ones;
then I'll go with small solid-lifter fast-rate-of-lift cam, but realize that the logs will kill the overlap, which is at least 50% of the power increase . And
the late-closing intake valve angle of a bigger cam, will kill the bottom end by virtue of failing to trap, even as modest an amount of A/F charge that the stock cam did. The bottom end can quickly feel less like a 318 and more like a slanty. aaaaaaaaand
now you need a higher stall convertor.
>For these reasons, and I know you didn't ask, I recommend a high stall before anything else. And a SureGrip rear gear that traps you at the right rpm.
I didn't vote, because you did't provide a third option, namely stall and gears.
Yes, we are having a ... REALLY .... HARD TIME ... and I mean REALLY tough time selecting one of two options ..... I thought I drew up the parameters really straight forward and easy to understand.Like I mentioned before. If you are only doing heads or only doing cam, I think the cam will do you the most good. If you are thinking about adding the other later you might as well keep what you have and build a engine with a purpose. Like me and my 70 318, It has dual exhaust and a Pertronix. I have a LD4B and a AVS2 to put on but I haven't yet. I also have some 68 340 manifolds and will replace the exhaust. Half of it is till the original single split and made into duals. Get the intake off I am staring at the cam and the 50,000 mile old original timing chain might need replaced. Hell, I might as well pull it and build it with the Speedmaster heads I have stored in the basement. Or better yet, get a 360 Magnum. Where does it end? There is no good answer!
Define one notch up in cams size.It depends on your long term plans. With a stock engine you can only move up one notch to a slightly hotter cam.
Depends on the grind of the lobes and many other factors.If you add heads / raise compression later the cam may not be enough and get wasted….
Not needed but would result in better results.depends how far you want to go. Heads won’t be a waste but may not add a ton of power on their own (like any component) I’d do nothing until you can add compression.
Thanks. If only a stall was one of the two options....Torque converter. 3500 stall. You will be surprised what that will do. Then put a cam and springs in it . Then save up for a set of aluminum street heads.
Ya read my post again. It isn't easy. You have enough cars, like racing, and have a following, you need to build something with a purpose. A component at a time can work but it needs to be planned out ahead very carefully. I get it and so do you.Yes, we are having a ... REALLY .... HARD TIME ... and I mean REALLY tough time selecting one of two options ..... I thought I drew up the parameters really straight forward and easy to understand.
