I wish you were closer....I'd grab a 12 pack and head over to your house.
I hate to be whipped by a piece of iron. LOL toolman
I know there is a certain procedure for that but I just spin the motor over until
the intake valve closes. You will be on the power stroke and both valves will be closed. The stock specs for valve adjustment are .013" for the intake and .021" for the exhaust. These should be set hot but should get you started and then you can readjust them after the engine warms up. These specs are for a 1966- HP273 with a solid lifter cam by the way. I got the info from a factory service manual. Good luck! toolmanmike
dam i could have sworn i mentioned something of this afect about valves being to tight??
I had a similar case with low compression and the engine not wanting to start. I checked the valve timing and it was out, I had installed the timing chain using the wrong indexes and it was a few teeth off. You can check the valve timing without removing the timing cover. If you have a factory service manual, follow the directions for checking the valve timing. Even if it`s not the problem it`ll rule out that variable.
I do everything by hand. Start by pulling all the spark plugs out. Turn the engine clockwise only, tighten, on the crank bolt. Add about .002" to both gaps because it is cold. My guess for gaps are .016" for intake valves and .021" for exhaust valves. Some cams call for a .028" gap hot. Anyway, that means you need a .018" feeler guage for the Intake valves and a .023" feeler guage for the Exhaust valves. Turn the engine over by hand and adjust the valves while they are on the base circle of each lobe. As you move through the lobes go back and keep checking the gaps of the other valves that are on the base circle and tighten or loosen as necessary untill you are confident that they are all gapped correctly. I've found the charts are not the end all. When this is done, screw in a compression guage into #1 cylinder and turn clockwise untill you start getting pressure. A finger in the spark plug hole works too. Keep turning clockwise untill your damper is at 0 degrees. You should be at TDC on the compression cycle. Always check TDC on the timing marks is TDC of the Piston. Mixed dampers and front covers? I've seen them way off. Now pull the cap on the distributor. The rotor should be under #1 spark plug wire terminal. You have Compression. You have Fuel. And you have Spark. The engine should fire right up. Adjust timing. Do your cam break in. Then, I make the final adjustment with the 016" feeler guage for intake valves and .021" feeler guage for exhaust valves with the engine running. Can you say messy? Readjust after about 5,000 miles and you should be good for almost ever.
On the mopars you can't adjust when it's running since they are not pedestal mounted.
When you adjust your valves do as 66fs but instead of adding .002 to the cold tolerances you`ll want to subtract it.
I read what you did and this is {{{what you wrote.}}}AND WHATS WRONG
1)I pulled the left valve cover and found TDC for #1 by watching the intake valve just start to open. Then I backed up the crank a bit to get the timing mark right at zero.
2)At TDC for #1 cylinder, there is some preload on the exhaust valve. As I understand it, that should NOT be the case, right?
THE REASON YOU HAVE PRELOAD ON THE EXHAUST VALVE IS BECAUSE WHEN YOU WATCHED THE INTAKE VALVE OPEN AND THEN BACKED THE MOTOR UP TO WHAT YOU THOUGHT WAS TOP DEAD CENTER ,YOU ARE ACTUALLY IN BETWEEN THE INTAKE AND EXHAUST STROKE FOR THE ENGINE.
THINK ABOUT IT IN THE RIGHT ORDER FIRST
POWER \ EXHAUST \INTAKE\COMPRESSION
TOP DEAD CENTER IS AT THE BEGINING OF THE POWER STROKE AND THE MARK ON THE DAMPER ,WILL LINE UP ON YOUR TIMING TAB.,
BUT IT ALSO LINES UP ,ONE MORE TIME ,WHEN IN BETWEEN THE EXHAUST AND INTAKE STROKE.
(((THIS HAPPENS TWICE )))I THINK YOU BACKED IT UP TO WHAT YOU THOUGHT WAS TOP DEAD CENTER ,BUT ARE REALLY IN BETWEEN THE EXHAUST AND INTAKE STROKE.
THIS IS WHY YOU HAVE PRELOAD ON YOUR EXHAUST VALVE.
1)VALVES ARE CLOSED ON THE POWER STROKE
2)THE EXHAUST VALVE OPENS NEXT <<<< PRELOAD ON VALVE
:hello2:YOUR IN BETWEEN THE INTAKE AND EXHAUST STROKE
3)THE INTAKE VALVE OPENS
4)THE NEXT STROKE IS THE COMPRESSION STROKE {{ VALVES CLOSED}}
DO THE SAME THING YOU DID BEFORE BUT DONT BACK THE MOTOR UP , KEEP GOING 90 MORE DEGREES CLOCKWISE TILL TOP DEAD CENTER.
THEN CHECK THE DISTRIBUTOR AND MAKE SURE IT'S ON #1 ONE CYLINDER ON THE CAP.
PUT THE WIRES ON GOING CLOCKWISE [ 1-8-4-3-6-5-7-2-}
:thumrigh: DOUBLE CHECK THAT YOU DID THIS RIGHT (WHEN YOUR ALL DONE WITH THE WIRES AND DISTRIBUTOR )BY ROTATING THE ENGINE OVER BY HAND AND WATCHING THE EXHAUST VALVE \\\ IT WILL BE THE FIRST VALVE TO OPEN AFTER THE POWER STROKE
,AND SINCE THE WIRES WERE PUT ON RIGHT ,AND THE DISTRIBUTOR WAS INSTALLED CORRECTLY, IT SOULD FIRE UP.
GOOD LUCK:salute:
A better way to get the motor at TDC on compression is to watch the intake valve. After it closes, the piston is on it's way up. That's TDC compression stroke.
The gasoline is fresh and the 4 bbl carb is from a running 318. The 273 turns over nicely and occasionally tries to start. A couple times it started and ran for a second or two but did backfire through the carb or spit out raw gasoline.
I'm getting pretty frustrated. Any thoughts or tips from you experienced engine builders?
Thanks,
Bruce
[When you adjust your valves do as 66fs but instead of adding .002 to the cold tolerances you`ll want to subtract it. ] No this is incorrect. As the engine heats up everything expands and your gaps shrink, even more on the exhaust valves.
I apologize, 66fs is correct with your application, iron head/iron block. I haven`t worked with that combo and a solid cam for a while. The clearances are going to be different for every engine based a lot on block and head material. I find on my aluminum head 440 the hot/cold clearance varies about .007 so for example, if I want my exhaust lash at .019 hot, I set it at .012 cold. Probably the best way to set the lash would be to set it with .002 added to the factory specs (as 66fs said) and then run the engine until it`s hot (it`ll likely be noisy) and then measure again while the engine is still hot to see how close you are to the proper clearances. Here`s a link to a cam site to help you. http://www.cranecams.com/?show=faq&id=4
That´s how I do it every time, never fails.Re-read this, too.
