You guys are amazing… thanks for all the valuable feedback. As a total novice when it comes to this stuff, i just don’t want to buy a hydraulic roller set up then wished I’d went solid… or vice versa. As you can see from some of my earlier posts I’ve been researching heads for a while now.. I’ve done the mental exercise of what magnum heads would entail, 302’s, EQ’s, my old 587’s, Speedmasters, and finally came around to Trickflows. I’m pretty set on keeping the 318. I do like the idea of a high revving small block. I’m sure eventually I’ll build the bottom end, but for now I want to run what I got…I’ve stumbled across a few 318’s with stock bottom end/trickflow heads that are making impressive power, using solid roller. This is one:
https://youtu.be/o_rGgaJ169U?si=E6TO_GF89QVspGZl I know he’s since done a full build but I would love a 318 running 7’s in the 1/8th (mid-high 11’s in the 1/4), which I believe is probably around 400 hp.
A brief overview of what mine has for anyone that wants to know: 1406 4 barrel Edelbrock Carb, Weiand Stealth intake manifold, Dougs D453 headers, 2.5” duals all the way back with H pipe… Stock 2.76 granny gears at the moment. Currently very mild.
The car feels “peppy” but not fast by any means. My butt dyno believes my current set up might be around 190 at the wheels… pretty laughable. I know heads and gears are holding me back quite a bit at the moment, so those are the 2 things I’m taking care of asap, but due to budget it’s one thing at a time…
