FWIW, when I took the check-mark out of "residential" on my address, that's when I got back the option of free ground shipping. Otherwise, only next day and saver options would list, at several hundred dollars each.
Might be. I can't remember if I checked residential or not on the second attempt.FWIW, when I took the check-mark out of "residential" on my address, that's when I got back the option of free ground shipping. Otherwise, only next day and saver options would list, at several hundred dollars each.
Buy a set and let us know you'll only be out $703...What is the quality of these heads out of the box??? Guide clearance? valve job??? Are they even any good?
No...... the heads aren’t as nice as something like a TF head.
But...... you will have enough $$$ left over to have them looked over....... and even after that still have some $$$ for some “extras”, like head bolts, gaskets, maybe an intake manifold, etc.
The bottom line is, you shouldn’t be expecting the same level of fit and finish as premium parts when the cost is about 1/3 as much.
How do you get free shipping? I have to click on delivery method which adds shipping.
I ordered my small block heads yesterday. During checkout it brought the shipping options up, it was already set to the free ground shipping. It didn't come up until I was on the checkout page.
I had checked the residential box so I Logged out (cancelling the order) and logged back in rebuilding the order. Got the free shipping once all was correct.I ordered my small block heads yesterday. During checkout it brought the shipping options up, it was already set to the free ground shipping. It didn't come up until I was on the checkout page.
We here at FABO probably ordered $100,000 of parts in the last few days.
Those small chamber aluminums should perk up your teen a bit I would think. I don't know how your iron heads flow but these are as good or better by far and a increase in compression will help your bottom end.Ok, I was either going to kick myself If I missed the deal, or my wife is going to kick me if I did, Either way I was going to get kicked, so ordered a set of bare heads, studs and 1.5 stainless roller rockers. Now we need to get recommendations on good valves to use! Springs will depend on cam choice. I have a 30 over 318, Performer intake, 650 Edelbrock carb, but no clue on cam, compression ratio etc. was in the car when I got it. I added a set of Dougs Headers and 2.5" Pypes Exhaust. Heads on it currently are 360 cop heads according to the number. So probably do some clean up and gasket match on the SM heads, slap either ld340 or ld4b ( I have both) on it and call it good. Car still has 7 1/4 rear end. It's convertible that I'm converting to 4 speed, but will be just a cruiser/street car.
Hurry, you can still get a Speedmaster racing shirt and hat. lolJust under 7 hours left!!!..
Right now I'm not buying the intake manifold and I absolutely have no use for an do not know what I would put/use it on just driving me nuts!!!..
I just know I want to do a magnum swap one day...
