clifftt
Thanks for sticking with me, Gents! I will double check the rods.
You mean accelerator pump? I will check it, it was replaced from the kit.EDIT: check squirter pump while you have the top off of it.
Yup never know if the squirter pump (accelerator pump) is set to high, float set to low or that little plastic tube is trying to fall off.You mean accelerator pump? I will check it, it was replaced from the kit.
I'm not sure the transfer slots apply to AFB do they?
The bottom of the manifold was opened up when at the machine shop and all the crud cleaned out. Man, it was packed! I'll explore my choke options.The choke pull off only opens the choke so much (not all the way)
It is designed to open the choke just a little when the engine fires up.
The rest of it opening relies on the bimetal spring as the engine gets hotter, and sometimes they don't open all the way due to a plugged up crossover in the intake. (usually older OEM manifolds)
The other reason is that the bimetal spring that controls the choke is bad.
An electric choke conversion kit for that would be nice to have.
Are there any holes drilled through any of the butterfly plates?
You may be lean now.......let the choke be half way closed and blip the throttle. If the stumble improves......Its lean
aka may need bigger jets or a different metering rod that does the same thing.
