Has to be the cleanest build on here!
A collage of numbers.
I think all but one is pictured here. Can you tell which one is missing? :happy1:
AlV 69 Dodge GTS project
Like This Page · 15 hrs · Edited ·
A new slip yoke from Denny's drive shaft ad 2 new moog unjoints, press then all together and Bam drive shaft ready to go back on.
I think I solved the overheating problem.
160' stat and burp the motor of air. Now she runs at 160 ish with 22' initial timing with 35' total 900 ish idle in neutral.
Al, did you press everything yourself or did you take it somewhere?
Put that sucker in and your ride will move and stop right? That's huge :burnout:
We're going to need the do the same thing for Misty..I hope my slip joint is the proper spline count for the transmission...
Trying to make the gauge kit look like it could be a dealer installed option
Gauges Installed and working.
Definitely! thinking about putting one on the Column.Do you disable the original gauges or doubling up?
Plans for a tach?
Nice Al ! Real Nice !Getting some sun after almost a year in the garage.
View attachment 1714921012 View attachment 1714921013 View attachment 1714921014 View attachment 1714921015 View attachment 1714921016
also, the temp gauge, amp gauge and oil light on the dash still work![]()
Keeping with the dealer installed idea, this is my tach choice with the red/orange needle. Pre 60's Sun green line.
I like the look of that Sun Tach.
I'm probably going to go with a SW tach for the steering column to keep with the SW gauge theme. Might need to get a POD for mounting it.
