Nevermind. Again.
RB,
What they teach down under is physics & how to read, both instrumental in understanding how an air bleed works in a carb.
Not sure if I posted this earlier in this thread, but this is from the Carter Carb book by Dave Emanuel, p. 26. It couldn't be more clear....
'....a reduction in bleed size reduces vacuum signal requirements & fuel flow is more easily initiated'.
A smaller [ not larger] AB starts the system SOONER.
You know, I hear toilets flush backwards down there. Maybe you should give him some slack. lolYep, and he’s WRONG again.
You know, you can test this on the dyno. You can test it in the car if you have a data logger. If you had access to that you’d see how wrong you are.
And I’ve already pointed out to Hysteric that you have different physics. And you BOTH failed reading comprehension.
Carry on and be wrong. There are guys on here who have tested the MAB and the results. And oddly, their results match Taylor. And my results.
Of course, down under it may be different.
RB,
What I am not deluded about is how ABs work, & neither are a lot of much smarter people than you are.....
And as for 'physics' our southern physics is the same as your northern physics, only yours is different, to suit the occasion.
Vegimite has one g...
No carb function is the same, if that surprises you. You also do not need to know algebra to understand how an air bleed works....for either hemisphere.
I am quite happy to have a civilised discussion with you about emulsion.
I am not sure what you mean by function of emulsion above the fuel level?
The entry to the booster is 1/4 -1/2" above the fuel level in the fuel bowl, for all venturi style carbs & this is the theoretical level in the main well that feeds the booster. This is called the spill height. In a running engine at idle, the fuel level in the main well is actually slightly lower than this because nearly all American carbs take idle fuel from the main well. The only American carb I am aware of that does NOT supply idle fuel from the main well is the Comp Series TQ. It, like some Weber & Dellorto performance models, take idle fuel direct from the float bowl. I assume this is for more accurate metering of the main system.
To get fuel to the booster entry, the fuel has to be lifted 1/2". What does does that? Atmospheric pressure acting on the fuel in the bowl pushes out the fuel in conjunction with suction/depression at the booster nozzle. It should be obvious that any bleeding off [ MAB ] will delay the start up of the system [ the straw example ].
Air is drawn through the MAB which aerates/emulsifies the fuel in the main well. This makes it easier to lift the lighter emulsion as compared with solid fuel.
A smaller MAB starts the flow earlier because less signal is lost [ or bled off ] & a bigger MAB starts the system later because greater vacuum [ more air speed, higher engine rpm ] is reqd to overcome the signal lost to the bigger MAB.
I actually have some questions, but I gave the **** slam up several posts ago. Piss on both of yall.
Thanks Eric, I would tend to agree with you on all points. Now let me throw another factor in there. As i understand it, the air bleed is by design meant to be more of an activation tool that can also affect the mixture of the fuel going to the booster. The emulsion stack is where the mixture is actually created. Therefore if the emulsion is out of whack to begin with then it can throw off what the bleed is actually doing. Does that make sense? Hopefully we can get some good input to these questions without a bunch of useless fodder being thrown out with it. The whole thing is confusing enough for me without having to read between the insults.Looks good Mark!
I find it interesting every forum I go to, there are differing understanding of AB and how they work. Two groups arguing over the same info. Multiple experts quoted which seem to be saying the same info, but understanding it differently.
My understanding: With more air coming in the bleed, fuel is being aerated which in turn allows it to flow easier, which seems like it would come in sooner, but also the volume of fuel is less due to the aeration. Even erratic through the booster if the added air is too much. Does anyone agree with this statement?
I already know who I will believe. I'm not gettin in the argument and bullshit. I just wanted an answer.Ask them. You’ll get two different answers. Then go use them both and see who is full of ****.
Remember all the **** I got right here in this forum for telling people to stop using half intake idle vacuum to set power valve opening. A regular crap factory.
A couple of guys went out and tested it and found out that for decades Holley and their mouth pieces have been giving wrong tech. And they still do it.
Ask away. Then go test and post your results. That would settle it. Well it won’t because some will never learn. But YOU will know.
Looks good Mark!
With a bigger MAB, there's more air flow so it pulls more fuel. Not difficult to grasp.BOOOOOOOOOOOOOOOOOOOOOOOM!!!!
You GET it.
For those who don’t get what the argument is, read and read and read and read this over and over and over and over until it makes sense.
Your post is EXACTLY why a larger air bleed starts the mains SOONER. EXACTLY.
RB,BOOOOOOOOOOOOOOOOOOOOOOOM!!!!
You GET it.
RB,
I sent you a PM, not sure if you saw it, a while back. I was essentially asking your thoughts on my combo and what I am seeing. Would you be willing to take a look now that I am starting to get it?
