RAMM
Shhh--Don't tell the customer the balancer I'm putting on his engine is junk . J.Rob
your saying I should ditch the OE style rubber pioneer DA-3602
and install something like this SCAT SCA9012
I’ve never seen that. I’m assuming it’s an elastomer damper, but I could be wrong.
Scat harmonic balancers are made from bulletproof 1045 steel making them ideal for racing. Scat SFI harmonic balancers are designed to be installed on race engines that may rev over 10,000 rpm. Optimum damping occurs in the 6000 to 8000 rpm range. The machine work on these Balancers is second to none and the critical fit tolerances and balance are held more closely than OEM. They come with a gloss black paint finish and outlined timing marks for easier reading.
- Bulletproof 1045 steel Construction - extremely tough Balancer
- High RPM Design - safely to 10,000 + rpm
- Bonded Hub - elastomer bonded to ring and hub
- Timing Marks - white marks for easier reading
- Precision Machined - tighter tolerances than OEM. Precision fit to crankshaft, not like other cheap Balancers on the market
- Very affordable & High Quality - priced like the cheap Balancers but with the precision of the expensive ones.
Bullet point 3 is the deal killer for me.
ANY SFI damper is steel. Some are aluminum. None that I know of can get SFI approved if they are cast iron.
Guessing cycles.How long does it take for the elastomer to change durometer? Because the durometer affects the ability to control harmonics in whatever frequency it’s tuned to.
Asking becaus I don’t know, and I’ve never seen a paper on it.
BUT-BUT you said that Tom Lieb the owner of Scat crankshafts says elastomer type dampener is JUNK. I'm confused. Help a fella out. J.Rob
See post 38. Seems you misread what I posted. I’ve made no bone about why I don’t use elastomer dampers. Coincidentally, Chrysler came to the same conclusions. I knew that LONG before the book by Chrysler was written.
Guess you should have written the book first then. Tell ya what--go start your own thread and educate us schmucks about how the most commonly used type of balancer in the world is no good. Oh and don't forget to tell us what actually works and why please. J.Rob
Guessing cycles.
If i were to guess based on my own experience...but base it on track time around 300-350 heat cycles.
How long till its completely useless,800 or so. Maybe 6 years as a daily driver.
I pulled my pioneer off after 3 motors and 15 yrs... its about as hard as the edge of a sheet masonite.
Reminds me i need 2 dampeners, a throttle plate and a set of header gaskets.
I believe "junk ****" was the quote. lol
I said “junk ****” and somehow that get to that’s what Tom Lieb said.
This is how threads go sideways.
Again, as a percentage, how many of those junk cranks broke with an elastomer damper, and how many failed running a different type of damper?
I honestly have no idea, except to see the percentage of engines built with them I and certainly the lesser brands and even OE used up stuff and probably some “rebuilt” dampers certainly would be in the 90 percentile.
When I see damage like that, the LAST thing I look at is the blatantly obvious. Having autopsied many engines like that over the years, the blatantly obvious is almost never the cause.
Owner of Scat crankshaftsSo who is Tom Lieb?
