Hey John, I went to solid vent tubing. The foil hoses kept ripping.
Yesterday was a no-go with FAST tech support. I left a call back number and waited. We've actually had fairly good luck getting in contact with them. Maybe it was a busy day.
I did manage to put some time into project pinball. My first attempt at printing an overlay for the back glass didn't turn out so well. The vinyl I tried printing on wouldn't absorb the ink. It beaded up and distorted the image.
Luckily I had gotten material from more than one vendor. After crappy results with that first sheet, the rest printed fine. I ran out of vinyl before I was done and ordered more. Although this vinyl is self-adhesive, I used scotch tape to hold the pieces to the glass for now. If I get them to butt perfectly I'm hoping there won't be any seams showing. - Otherwise I'll look at having a vinyl shop produce the image in one piece.
I still have to modify the backlighting so the two cars, Thunder Valley logo, & christmas tree are lit. Right now you can see bulbs shining through in areas I want kept dark. I imagine I'll have to paint a large portion of the backside of the glass to control illumination. It'll also mean deleting some lights and adding others. I don't think it'll be a success if I don't get the lighting right.
In order to use these 'modded' pop bumper caps with the LEDs I'll have to solder some wiring. I've been finding out that replacing all the bulbs with LEDs is a mistake. In some areas regular bulbs disperse light better. I guess I'll be using a combination of the two.
Pin ball machine looks great, also love the 70's carpet in the room.
As for the FI set up I would have never bought it, a carb on my old truck starts easier in the winter than the FI on my Jeep.
EFI works on a daily driver some what. Compromise on everything.
I hate the drive by wire system on my challenger.
Nothing like a throttle cable hooked to a carb sit up right.
Sounds like FAST is a money grubbing company.
Thanks Sireland. I'm wondering if I wouldn't have been better off printing the back glass differently. Maybe I should have just painted the background black and then attached the various images on top. Then I wouldn't have concerns about having any seams show. I think that's the route I'll take when applying the images on the table top because it'll be a real pain to try to cut & fit around all the weird shapes.
The masochistic side of me still says the efi will be great once dialed in. Once (if) we get it working properly, my next concern is how reliable it will be. I doubt we'll ever become expert with this system but hopefully we'll be less stupid about it. I really value good communication and get discouraged when dealing with poorly written instructions or technicians that don't reveal complete answers to questions.
There is nothing wrong with the injection system.It works great. I went through this two months ago.Fast technical support isn't going to be able to get you where you need to be with the injection system.They are only going to be able to give enough information to help get it running.I believe they have a time limit on there support and a lot of there techs know the system but do not know how to tune.I have that same system on my Supercharged Hemi and it works great.
I built my system like you and your son.I am only trying to share this advice to help.
If your struggling with how to change the fuel mapping or the timing mapping you will need help from someone who tunes injection or someone who will answer your questions.I tried FAST technical support when I got my car running and went through the exact frustration your going through now.If you know someone who tunes that would be your best bet.If not you could call rich at fastman EFI. For 250 dollars he will answer all your questions and work with you on a tune by sending data logs through email.John you and your son will enjoy the injection.I do understand what your going through I thought I would be able to tune mine and unfortunately my system with the blow through was just to complicated for me.I would sink the timing on the distributor to the computer that will help it start and run.I had the same problem and that was the first thing we did during the the first dyno session.
The fact that you and your son are doing this together even if its not going the way you thought
is AWESOME!!Stay strong you'll get it going.
I thought I would never get my car running right either but I drove it last night and it runs great.
Thanks,Joe
I am old school but FI is the shiznit. Anybody who says carbed is better, well, living in the past. No offense to any one. Fuel injected is sssooooooooooo much better in every way. The tuning is the secret. Pay someone who knows what they are doing, you will never regret it. rayer:
LOL! I know what you mean. When we fired the Roadrunner up those foil ducts went totally spastic on us. I didn't expect them to jerk around so violently. It was like watching a Sasquatch have an epileptic seizure. One side blew off right away and the other tore just past the end of the exhaust pipe. I ended up using zip ties to hold the pair together and then placed a transmission blanket over them to keep them from jumping around. I'd seen that you modified your setup with solid tubing. - NOW I know why.
Yeah, I was really surprised to see the action on them hoses, too! I thought the mufflers would smoothen the puffs out but no. I also tried wrapping a blanket around them to keep them in place but it didn't work for long.
You know Mitch, we've definitely had second thoughts about the conversion after reading so many people having problems with it. Our own experiences have probably been similar to those folks. If it wasn't for guys like Joe that went through the frustration and eventually got it to work (and work REALLY well) we'd probably have a carb back on the car now.
There's no doubt it's been a struggle but we've been slowly learning more & more as we go. I'm glad we didn't take the car in and have someone else set it up right after we bought it. They say you learn from your mistakes and it's true. We still haven't mastered the FAST efi yet but we know much more about it than when we started. Most likely we'll have FASTMAN walk us through the final tune but we'll have a better understanding of his steps when we do.
I don't pretend to know everything when it comes to cars (or anything else) but I'd like to think I'm not becoming one of those people that has someone else do all the work for them. There's nothing wrong with going to others when you run into a brick wall but I think we're still a few feet away from hitting it.
I guess I didn't exactly make myself clear on this subject. I wasn't bashing your efforts at all, I encourage that. Learning everything you can about what you are working on is paramount to doing it correctly. Having said that, I have short term memory issues that make it really difficult to "learn" new things. (accident related)
I am a pretty smart guy but teaching myself to "learn" a computer, (which is what you are trying to do, somewhat,) is near impossible without ALOT of time spent.
That is one of the reasons for having someone that does this on a regular basis and knows what they are doing, do the job. I have been down the same road you are on right now many times. Finally came to the conclusion that it's FARRR CHEAPER to have an expert do it for two main reasons.
1. All the crap going on in my life doesn't permit the cost of time loss/ gain in the endeavor. Plus, I am always second guessing myself if I have everything in correct parameters.
2. One little miscalculation anywhere in the set up or drivability can be disastrous. It may act and drive alright but really isn't. Setups that took me weeks of studying and work led to bad outcomes with thousands of dollars flushed down the shitter. :violent1: So, not only did I loose time in the study aspect but also monetary repairing some things that would have only cost me a few hundred if I hadn't been a stubborn stingy fool who thought that tuning isn't that hard, I can do it, anyone can...............
One more thing, tuning a car to get the most HP out of it is an art. But realize it is tuned to the nats ***, no room for error. On a street car, this is stupid. One tank of bad gas and the engine is junk. Saw this numerous times.............
Just putting out words of wisdom here. Not saying anybody here can't teach themselves how to tune a car. I am just saying, don't fool yourself into thinking it's not that hard......
Oh, and don't forget drivability. A lot of people just tune the dyno, bad idea.
Hope this helps. :cheers:
Now go to bed.
