1967 'cuda
Dropped on Head as a Baby
The front seat wasn't hard to unbolt. The difficult part was trying to wrangle it out of the car by myself without marring the upholstery. With limited usable floor space in the garage I decided to rest it on the trunk lid for now.
With the seat out I've finally got enough room to lay under the dash. The shifter competes with my left shoulder when I try to get comfortable. I put a blanket down to keep from damaging the carpet with any dirt or grease.
I need to become a better person. If I don't I'm surely going to hell. After tearing into the Roadrunner dash wiring I've realized that there's a good chance that I could be made to work on under dash wiring for all of eternity. (it's too late for the engineers that designed this setup. - Those sadists must be down there already.)
I didn't use Chrysler or Chilton's manuals when I dove into this project. It's been awhile since I've gotten into a B-body dash dis-assembly but it's pretty straight forward. I do have a copy of the Chrysler manual on my computer that I do use and will be checking it when it comes to the wiring diagram.
The aftermarket radio, tach, and fuel injection wiring didn't make this job any easier. I had installed those items without removing the cluster so the wires for them weren't routed the nicest. I may re-route them now so that they can be bundled better.
So far I haven't found any issues with the wiring that I've inspected. There aren't any places worn bare or rubbing against things (such as the wiper arm assemblies). The only damaged wires appear to be the few inches of the pink and black wires coming off of the headlight switch.
I'll keep looking. After spending this much effort to take things apart I won't start putting anything back together until I'm sure I've found the problem. I'm not looking forward to removing the electrical tape that wraps the harness. It's not very likely that the wires will be bad beneath the tape but I want to make sure.
After visually inspecting all of the wiring I'll begin testing to see where the circuit is grounding out.
