Man I wish we had one of these stores locally.
Print it out and see if anyone local does price matching...Man I wish we had one of these stores locally. View attachment 1715886592
Same here. In 1973 went to a Chrysler performance seminar (year before Direct Connection).I've run type F fluid in all of my cars, dating back to the early 70's.
Yes, and I never have had an automatic ..!! I have run it in every 833 I have ever owned…Swingn’….Man I wish we had one of these stores locally. View attachment 1715886592
That may be true for some, but not all. Type F, at least the stuff I sold, has viscosity index improvers. Basic hydraulic oils don't. Using a hydraulic oil that is thin enough to work in a cold transmission in the dead of winter will likely thin out too much to work well fully warmed up in summer. Some more advanced hydraulic oils have VI improvers, but the common cheap stuff doesn't.Type F is just standard hydraulic fluid with a red die added.
YesSo type f is fine for all a904 and 727’s?
Yep, Different Friction Coefficients/ ModifiersThat may be true for some, but not all. Type F, at least the stuff I sold, has viscosity index improvers. Basic hydraulic oils don't. Using a hydraulic oil that is thin enough to work in a cold transmission in the dead of winter will likely thin out too much to work well fully warmed up in summer. Some more advanced hydraulic oils have VI improvers, but the common cheap stuff doesn't.
I knew a chic that ran Dexron or something in her Ram, instead of ATF+4.... had to R and R it.Never use type "A".
