Anybody Know Of An In-Tank Electric Fuel Pump...
ocdart
Inland Mopars Car Club
North OC, SoCal
that will fit the stock '69 A-body fuel tank opening without modification?
I know it's a long shot, but thought I'd ask.
I have a pump like this that I have always wondered the same thing but I have never measured it to see.
I don't see any reason to put a pump into a tank............................
Grab one (or 2) pumps off the tank of a Mercedes. They are external in a little isolated "nut sack" off the rear of the gas tank. The 4-6 cyls have one and the big boys have 2 in series! Mount inline to frame rail with stainless zip ties over rubber sheet, done. In tank pumps are quieter, thats about it.
The guy with the early Cuda that has built an *** kicker small block, DVR (?) Cuda sent me a linl to a shop that mods a factory tank so an internal pump is used.....will fire up my old busted up laptop and look for the link......
I should have mentioned I had a in tank pump in our 68 cuda rag but it was no quieter so I took it back out so it is easier to work on. I have fast ez efi on two of my cars . They work well
I believe [ame="http://www.rockvalleyantiqueautoparts.com/ndex.htm"]THIS[/ame] is the place that can give you what you are looking for. I had to email them because they did not have it listed on there site......[ame="http://www.rockvalleyantiqueautoparts.com/catalog/tune_port_info_and_kits.pdf"]THIS[/ame] might be what you are looking for....
