clair.davis
catching up...
Found some info on the '02-'07 16" wheels at www.jeepkj.com...
For the '08+ Libby's (KK chassis):
Not knowing anything else about the larger OEM wheels, I'd wager the backspace is going to be very close. Since the Mustang wheels are 5.7, I'd bet the Liberty wheels will fit well. I also would bet a dollar that the center bore is exactly right for BBP Mopars. The center cap is likely too small, though.
Clair
Info on Stock Wheels:
Bolt Pattern: 5x4.5" or 5-114mm
Backspace: 5.5" (might be a hair larger than this actually)
Offset is 41mm ( I know the chart says 38, but I found 41 from a tire vendor that said the factory wheels are 41 )
Wheel size is 16 x 7
Stock Tire Size ranges, but 235/70R16 is most common.
The OEM KK rims specs are 16x7 with 5.5" of BS.
Clair
