1973dusterkid
Watch This
Also how do i wire it one wire to hot side on coil and one to ground on coil
So hot wire to coil and ground the distrubuter to chassis
All you hook up are 2 external wires, 1 to the "BAT" 12v & the other is coil, it should say it on the cap, the other 3 are pre-wired from the dist. & it clips into the cap. DO NOT run a separate wire to the chassic & ground the distributor!!
I don't believe this is what he has, refer to 70AAR above
