I bought my car from someone who didn't seem to know much. The car would run but stall when going into gear. If you increased the idle you could hold the brake and get it to clunk in and go. The previous owner said an old Mopar guy told him it had a vacuum issue... I was skeptical as well. While tracking down the issue that was the first thing I discovered. After tracking down vacuum, carb linkages, bad electrical connections; which were many. I swapped the battery, starter relay, ballast resistor.. I had the transmission and converter rebuilt, which it really did need as 3rd gear was completely gone and the converter was completely shot. I had a shift kit put in and am happy with the results, but I still had starting and stalling problems which may have been related to this, I thought neutral saftey switch but it turned out to be the switch connection. Someone, including myself and the transmission guy should have picked up as it was wrapped in half a roll of electrical tape.
Even though a bunch of issues may or may not have been a factor I wouldn't go replacing that booster or neutral safety switch just yet and keep looking.
