Axle seals are leaking again
Transmission and Drivetrain Tech
  1. RustyRatRod
    RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
    71,464
    46592
    Jun 7, 2010
    Georgia
    Local Time:
    8:22 AM
    This kit has the original lookin Chrysler inner seals. See how they're rubber coated over the metal? I've even seen some original OEM ones that were all rubber. Just real thick rubber.
    • Thanks! Thanks! x 1
    • RustyRatRod
      71,464
      46592
      Jun 7, 2010
      Georgia
      Local Time:
      8:22 AM
      Negatory ghostrider, it sure doesn't.
      • Agree Agree x 2
      • RustyRatRod
        71,464
        46592
        Jun 7, 2010
        Georgia
        Local Time:
        8:22 AM
        ....at least it ain't supposed to. LMAO
        • Agree Agree x 1
        • Car Nut
          Car Nut Mopar Master
          18,363
          76885
          Dec 28, 2018
          Trump Train
          Local Time:
          6:22 AM
          Dang, i'm going to pull my axles now and recheck for outer seals.
        • RustyRatRod
          71,464
          46592
          Jun 7, 2010
          Georgia
          Local Time:
          8:22 AM
          If you have any misgivings about them, it sure wouldn't hurt.
        • dadsbee
          dadsbee FABO Gold Member FABO Gold Member
          855
          1784
          Nov 25, 2020
          Penetang, Ontario
          Local Time:
          8:22 AM
          OE inner seal... has metal OD..
          • Car Nut
            18,363
            76885
            Dec 28, 2018
            Trump Train
            Local Time:
            6:22 AM
            I agree it's out of the car anyway.
          • Car Nut
            18,363
            76885
            Dec 28, 2018
            Trump Train
            Local Time:
            6:22 AM
          • dadsbee
            855
            1784
            Nov 25, 2020
            Penetang, Ontario
            Local Time:
            8:22 AM
            That's just the locator tool... lol.. this is the remover..
            • Like Like x 1
            • RustyRatRod
              71,464
              46592
              Jun 7, 2010
              Georgia
              Local Time:
              8:22 AM
            • MoparLeo
              MoparLeo NRA PATRON LEVEL LIFE MEMBER FABO Gold Member
              694
              443
              Feb 10, 2016
              Moreno Valley, Cal. So. Cal.
              Local Time:
              5:22 AM
              Inner seal, is an oil seal. The outer seal is a Grease seal for the bearings. The inner seals are commonly damaged when installed improperly. The axle must be centered when reinstalled and not allowed to drag across the seal. The seal lip should be lubricated with Lithium or similar grease so as to not drag on the bearing surface and get damaged. Follow the Factory Service Manual and you will see exactly what parts go in there and how to properly change them. Not complicated. If something is damaged, replace it once. Don't try to save it twice.
              Just a question...when was the last time that you checked/adjusted the axle end play ? If they are loose, they will leak. No matter the axle condition. Grooves in axles are never good. Sleeves are just that, a temporary condom.
              • Agree Agree x 1
              • dadsbee
                855
                1784
                Nov 25, 2020
                Penetang, Ontario
                Local Time:
                8:22 AM
                Exactly what I asked the OP in post #7... still waiting for him to come back.. :poke:
              • Jadaharabi
                Jadaharabi FABO Gold Member FABO Gold Member
                8,856
                9836
                Jan 8, 2016
                Peoria, Illinois
                Local Time:
                7:22 AM
                Well Rusty I learned something from you today.
                All these years I never noticed that outer seal.
                And I replaced quite a few axle bearings. A lot of them I replace them with the green bearings so I wouldn't have noticed that anyway. But the only reason I can think there would be a seal out there underneath that adjuster or that axle retainer would be just to keep dirt out of getting into the axle bearings. Because the inner seal should keep all the rear end fluid inside the housing.
                So a big thumbs up to you Rusty.
              • SGBARRACUDA
                SGBARRACUDA ROY FABO Gold Member
                19,833
                8260
                Dec 7, 2006
                PLANT CITY FL. and PERRY GA.
                Local Time:
                8:22 AM
                Outer seal is there also to keep the grease that you pack in the OEM bearings from getting contaminated and from washing out. Reason most people do not know much about them or routinely replace them is because the bearing has to be removed to replace the seal in the retainer.
                • Agree Agree x 1
