joec
Possibly but 10 hp moved into a better place in the
rpm range can possibly help gain a 10th.
This is a very good thought. Into the pump by brake-torqueing at the line.... leaving little pump left on the mash. I did notice the DP pump arm off the cam had the spring mostly collapsed. Not allowing the spring to continue the pump..... I might have another arm, just in case it's bent. I'll have to see what I can scrounge up for cams on some of my other carbs I have laying around.You need to dial in the pump shot to try and get the 60' back. I launch at 2K and found that using a white cam primary #2 hole in both the cam and throttle is best for me. #2 delays the shot a little and leaves more shot available when you launch. Rear cam is pink #1 hole, both 33 nozzles. Test, test looking at 60' times.
Mopar Distributor/Mechanical Advance Timing Limiter 610877674114 | eBayWhere do I get one of those plates?
I don't know, haven't really run it yet. Had it a few years though ... LOL.slight derail, 318 did you ever have a problem with advance sticking when using the plate, because I do
16 advance. I also replaced the heavy spring with a Mr. G spring .So, what did you set it at?
I love that plate, some of the best money I ever spent, since my timing got changed more than once.
No sticking so far with mine, btw.
I just hate that damn clip in the shaft. I use hemostats on them.
I honestly can't remember if I used two silver springs, or just replaced the heavy one, but I think I must have left the light factory spring, and I may change that to bring it all in sooner.16 advance. I also replaced the heavy spring with a Mr. G spring .
well, they only raced the 1/8 mile today because of weather. I ran, but ran the "low dollar 318" because I did a carb swap. We left in the rain, drove out of it and made a few passes - and ran the best times both 60 ft and 1/8 the car has ever made. Only change was I took off the 670 Holley and put on the 770 Holley.have fun, looking forward to your results.
Mid 8's wouldn't be too bad if you give it a little help with gears, converter, and headers. My teener is NOT set up for the 1/8... LOL... 2.76 gears and stock converter with a full weight car is not how you want to set 'em up, boyz…All I have around here is 1/8 mile tracks so when I look at yalls time slips I have to look at the 1/8 to relate. Lol I really hope I can get 9.5s out of my teener. I'd like to get in the mid 8s eventually.
Timing mark was going crazy... LOL. fluctuating about 10 degrees. Funny thing is, when it was revved, it would go to full advancement then drop 10*… LOL. I'll have to take it back apart.
Love to see you try those spitfire headers.Season is over.….. See what I storm up by next spring.
That’s odd, I have 2 of those plates and the timing is dead on. Maybe another issue. Goodluck.Timing mark was going crazy... LOL. fluctuating about 10 degrees. Funny thing is, when it was revved, it would go to full advancement then drop 10*… LOL. I'll have to take it back apart.
- P.S. - I tried it in the 318 because the car was handy.
you remembered I had those???? LOL...Love to see you try those spitfire headers.
I remembered you had talked about trying headers. When I went looking for the post, I found the ones where you had tried out the spitfires for fit.you remembered I had those???? LOL...
