mellow_utah
Ok, so my k member is bent, it looks like its been bottomed out on the passenger strut mount. The passenger wheel is actualy back approx 1/2" from the drivers side. My question is, hopefully its not to dumb, but is it worth swapping the K-member or buying some adjustable strut rods to make up the distance that the strut rod mount has been bent back? I could swap the k member if I can find one but its a bit of a pain if an adjustable strut rod would do it. My main concern with going the strut rod route is the geometry because one strut rod would be adjusted aprox 1/2" farther in than the other side. Any input? Thanks!
