best way to repair twin scoops
This would be my approach.
I agree with @72bluNblu that any decent filler will work.
If the pits are no worse than what I see in the picture, I would just use a good quality glazing putty (some call it a spot putty. It usually comes in a tube. It is a bit thinner than regular filler; it would probably spread on easier and fill the pits easier, and it sands easier than regular filler.
thats is what I went with, the spot putty, thanks.
what glue is used for the stud kits on the scoops? jB WELD?
Glue? The studs screw in.
If the scoop is damaged there or the threads are loose in the scoop it would basically be a fiberglass repair, so, anything compatible with fiberglass would work.
