Shopping list -
Large ring terminal to run ground wire from neg post to radiator support.
Fuel filter, fuel hose
OEM style hose clamps
Hose clamp plier
PCV valve grommet
Correct vacuum fitting for intake manifold.
When the PO added the cruise control, he needed to replace the vacuum tap with one from a power brake car because the cruise runs off vacuum. I either needed to cap the fitting or find the correct one for my car. So I found one on eBay and its on its way.
Hose clamp plier
PCV valve grommet
